Finished up the Breeze radiator shroud assembly today. Nothing to difficult. Used two existing holes in radiator flange and made one additional 1/4" hole on each end. Drilled 6 1/4 holes in shroud lip and attached with included screws and locknuts. Finished up by setting four Rivnuts to attach fan with 8/32 x 3/4" machine screws.
This was an old style radiator with the older breeze shroud that you had to cut yourself. No clearance or fitment issues at all.
In other news, I may need to update my signature line. Finally decided on an engine and builder and should have it around January. Probably overkill, but wanted to go big...FordStrokers 427 liberator long block. Having it basically finished out to turnkey.
