Turn signal switch
Good day,
I am having a problem with the turn signal switch. I have connected it as the Ron Francis harness as stated in the manual. When I flip the switch to the left or right I get the same result. 4 way flashers. But this should be left or right turn signal.
I have the 4 way flashers set up correctly. On a separate switch
stevenburgess
Good day,
Make sure your lights are wired to the harness correctly. I had a wire connected to the wrong wire of the RF harness and is causes both left and right taillights to blink rather than just one
