Results 1 to 2 of 2
Thread: Turn signal switch
    Apr 2014
    Turn signal switch
    Good day,
    I am having a problem with the turn signal switch. I have connected it as the Ron Francis harness as stated in the manual. When I flip the switch to the left or right I get the same result. 4 way flashers. But this should be left or right turn signal.
    I have the 4 way flashers set up correctly. On a separate switch
    Senior Member Jdav's Avatar
    ATL GA
    Quote Originally Posted by stevenburgess View Post
    Good day,
    Make sure your lights are wired to the harness correctly. I had a wire connected to the wrong wire of the RF harness and is causes both left and right taillights to blink rather than just one
    MK4 #9028 - Coyote - TKO600
    Delivery: 1/30/17 First Start: 7/23/17 Legal: 10/5/17 Graduated: 10/15/18
    Build thread: http://thefactoryfiveforum.com/showt...8-Build-Thread
