Results 1 to 8 of 8
Thread: Tremec TKO Transmission drive shaft seal
    Gatineau, Quebec, canada
    Quick question for those of you who have a Tremec tranny. on the end where the drive shaft go's in there's a rubber seal that in the manual says can be removed or pushed in. We tried both and it's really hard to move, what have you guys done with that rubber boot around the the tranny splints? Your help is as always appreciated!20180211_104531.jpg 20180211_104548.jpg
    AJT,
    I don't have this transmission, but my friend does and the way we got it to move was to use a little (Very Little) WD40 to loosen it up from the spline.
    We inserted the straw in a few places, then we used an Air Needle like you use to fill a football to break the seal.
    Then we could move it in or out with ease but we did eventually remove the thing.
    Good Luck & Have A Great Build!
    NOTE: I don't know if it is a good option to keep or discard the rubber do-hickie or not.
    I remove mine but no problem pushing it in if it's hard to get out.
    North CT
    Removed it
    Houston, TX
    Grab some pliers and start working on it, takes quite a bit of effort, but it will come out. WD40 suggested above might make it easier.
    North CT
    Quote Originally Posted by DarthTedious View Post
    I would stay away from WD40 as it will break down rubber seals and may damage the other seals that are needed
    Prairieville, LA
    You might know this already but there there are actually 2 pieces that make up the seal. There is a outer seal that is not removed which seals around the male splined shaft on the driveshaft when you put it in and then there is the inner seal which goes around the male splined shaft in the transmission which is the one you remove. You just need to pull back the outer seal lips and use a pair of pliers to pull on the inner seal. You just need to work your way around pulling on the inner seal at the 12, 3, 6, and 9 o'clock positions to work it out.
    MK4 #9237 - complete kit, Coyote, TKO600, IRS - Delivered 12/11/17
    Ohio
    I pulled mine out. Didn't seem to me it was going in the way it was made. Just be careful and take your time. Good luck.
    JRL16
