Thread: Transmission Conversion Torque Specs
    I got the 4WD to 2WD conversion done on my transmission last night, but I can't seem to find any torque specs anywhere for the "transmission nut" or the FFR supplied cover plate. Can anyone tell me what those would be or direct me to a thread that includes that information?
    Leesburg, VA
    Per the Subaru FSM, that nut should be torqued to 86.8 ft-lbs. You'll probably need to have the axles and wheels on and the 818 on the ground to prevent the nut from turning while you torque it. A new locking nut is P/N 802622020.
    The cover plate bolts can be hand tightened. The cover plate just seals the back of the trans so fluid doesn't leak out - it's not really structural. Don't forget some RTV behind the cover plate; I typically use permetax grey.
    Leesburg, VA
    Thank you!
