Thread: roll bar color to match wheels - any pics?
    Mar 2017
    Spicewood, Texas
    I'm thinking about either powder coating or painting my roll bars to match the color of the inside of the FFR wheels. If anyone else has done this, can you post pics. Also, does anyone have any information on the paint code for that color?
    LS1, TKO600, IRS, no scoop, undercar exhaust. Delivered June 14, 2017, First start December 31, 2017, Registered and Titled Sept 12, 2019.
    Grand Rapids, MI
    For the color code I would suggest you call FFR. Otherwise you be going through chip books, and chips don’t always reflect the actual color.
    Going from memory and I may be in error but I believe in the past the color code of the wheels has been discussed and the answer from FFR was they have used different suppliers for the wheels over the years and the color has varied slightly.
    I think matching the bars to the wheels could be a cool look. Since they are not directly adjacent to each other I think you get easily get a close enough match by using samples that nobody would be able to see the difference without them being right next to each other.
    Senior Member frankb's Avatar
    Feb 2014
    Marana, AZ
    If you have a "high end" custom or hot rod shop (i.e. Gas Monkey) in your area, they can match your wheel color. I used a shop in Tucson (for a previous project) and they matched the color perfectly! However, it wasn't cheap!
    FFR MK4 #8317, 393 Cleveland, Lunati VooDoo solid roller, CHI 3V heads and intake, TKO 600, Std roadster seats, 8.8 3.55 diff, 17" Halibrand replica wheels, Ford "Magnetic Metallic", silver ghost stripe. (Sold 10/16/21)
    Senior Member MisterAdam's Avatar
    Brentwood NH
    Gas Monkey.....high end??? they are one of the reasons why i got rid of cable
    Feb 2014
    Marana, AZ
    MisterAdam: Agreed! But they can still match the paint!
