Results 1 to 16 of 16
Thread: 15" Wheels - Wilwood Brakes
    Will 15" wheels fit over Wilwood rear brakes w/emergency brake built-in the caliper?
    Walter
    Member 3dGuy's Avatar
    San Jose
    16.5 barley fit. 17" recommended . If you look at wilwoods documentation you'll see what the clearances are.
    http://www.wilwood.com/BrakeKits/Bra...ear+End&whl=17
    My build site : www.ScootinThunder33.com
    San Jose
    Albuquerque, NM
    Kinda of depends on what rear differential. With the new IRS, you can go Wilwoods with 15" wheels, but not the parking brake. There just isn't room with the new spindle design to conveniently fit it in there. Several of us with this setup did either driveshaft mounting parking brake or hydraulic line lock. With old IRS and/or live axle, you can most likely fabricate the brackets to fit the spot caliper though.
    -TJ
    Maricopa AZ
    I have 4 piston kits front and rear that fit under 15" wheels.
    Gatineau, Quebec, canada
    FFR Recommends 17" minimum, I will be buying 18" to have a bit more clearance. I have an IRS on my 33.
    Using 15" Bogart bead locks and the Wilwoods do not fit. Only company that has a disc brake for a 8.8 Ford with the C clip eliminator is Aerospace Components in Florida. Luckily they are the same price as the Wilwoods.
    Seasoned Citizen NAZ's Avatar
    I have the optional 12.19" Wilwood brake kit on my 33HR with an 8.8 with Moser c-clip eliminators and I'm running 15" Weld Racing wheels with MT wrinkle wall drag slicks. To run 15" wheels in the rear I had to swap the caliper with the integral parking brake for a Wilwood DynaPro 4-piston caliper (Wilwood #120-8538) and use a manual line-lock for a parking brake (Speedway Motors #910-31301). To get around the c-clip eliminators I mounted the caliper brackets on the inside of the bearing flange and used aluminum spacers to get the caliper lined up with the rotor. It's a robust set-up and looks like a kit supplied by Wilwood.
    So Walter, if you want to run 15" wheels on the rear and still run a 12" brake it's possible using most of your Wilwood brake kit but there is no way those bulky calipers with the integral parking brake will fit inside a 15" wheel. And if you don't have c-clip eliminators it's even easier. The cost in brake system parts will be a bit over $400.
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Quote Originally Posted by Gordon Levy View Post
    This is what I used on my 15’s.
    Kyle
    Quote Originally Posted by KDubU View Post
    Ditto on Gordon's kit for my Thunderbird IRS and Trigo Wheels:
    Village Mills, Texas
    I have the 11.65 inch Cobra single piston brakes on the rear with the integrated park brake . Does anyone know if these will work with 15 inch rims?IMG_0630.JPG
    I am looking for more wheel and tire options than going with 20's.
    Oct 2014
    Vermilion, OH
    Andy, brakes clear the 15" wheels on my 33
    CVOBill
  14. Thanks HVACMAN thanked for this post
  15. #14
    Loveland, CO
    CVOBill, I am working on the '35 pickup and would like 15" wheels also. I have the FFR supplies 11.65" rear brakes. I just heard from Tony and he indicated I would need 16" wheels to clear brakes, but you got yours to fit with 15's?
    He also indicated he used 5.5 backspacing all the way round, but I am having trouble finding these in 16" Torque Trust.
    With full fenders he said 235 fronts and 265 rears are needed to fit.
    Any helpful hints would be appreciated.
    Ralph
  16. #15
    Mar 2018
    Bradenton, Florida
    I just purchased 17" bullit style wheels for my 33 with the Wilwood brake kits and guess what? They don't clear the rear brakes! The just barely rub the top of the caliper. I couldn't understand why until i realized the 10 1/2" wide rear wheel actually has a jog or hump on the inside of the barrel so essentially my 17" wheel is a 15" on the inside. I didn't see that coming, ouch. After doing some research I find out that a lot of wheel manufacturers have this jog in the barrel so beware of 17" wheels too, they are not all the same. I had read a lot about offsets and back spacing, bolt configurations, hub bore diameter etc until my head hurt, but never read anything about barrel diameters. The fronts are fine with about an inch of clearance because the barrel is flat.
  17. #16
    Quote Originally Posted by dan's33 View Post
    Are they rubbing the top of the caliper itself or the spot parking brake?
    If it's the spot parking brake you may be able to mill down the top to fit if the interference isn't extreme...
