Anyone else have an issue getting the rear ride height high enough using the 'R' shock location? On the drivers side rear, I can only get 3.375" height measured to the underside of the frame rail, and that is with some preload applied to the spring. The passenger rear does not seem to have the same issue, plenty of adjustment.
Thinking I may need to switch the the 'S' shock location in the rear so I can get at least 3.5" clearance, plus the springs will settle a bit with use and I want to be able to raise it up to compensate.
