Results 1 to 10 of 10
Thread: brake cable crimps crimper Swaging Ferrules
    May 2016
    I had to cut my brake cables they were much too long. I had them given to me by a member here and i need to crimp swaging ferrules on them at the forward mustang equalizer. All my parts are non donor but in this instance they were much too long and didnt work together.
    I need them to be like this. Is there a place you could recommend to buy a proper tool and swages for a proper fit using the cut down non donor kit cables?
    Grand Rapids, MI
    You need a cable swaging tool. These tools are around $100 for a decent one. Your best bet to save some money is to find a local aircraft mechanic as these are a common tool for them. I would imagine they would be willing to help.
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    2nd an airframe mechanic, or another idea...
    See if there's a local outfit/supplier for commercial chain & cable - a place that sells lifting, rigging, hoisting supplies. Back in the day doing "Pro-Audio" I used to fab flying frames for loudspeakers - using wire-rope, thimbles, and swedge fittings (NicoPress was the tradename).
    I'd bet that if you brought in your cables all set up & measured you could have them "demo" a setting tool & ferrule for you (and a $10...)
    John D. - Minneapolis 'Burbs
    I cut mine, over lapped them about 4 inches, and used three cable clamps on each to splice them back together.
    https://www.e-rigging.com/one-eighth...SABEgLBcfD_BwE
    Although I didn't need to, you may want to cut off some of you excess cable.
    Heart of Dixie, Alabama
    Lowe's Hdwe sells a swager for about $25 with single and double ferrules for sale. I used a single ferrule with some loctite under it. I am not on the road, nor using the brake cables yet, but it seems to be holding during testing. You can put 2 ferrules on the same cable or use the 2 cable ferrule with the cable looped back onto itself.
    May 2016
    Thank you all what thickness is the cables in the non donor cables from FFR? I cut them and removed a small part of the plastic for the swedge. They are installed so I don't want to pull them off the car. I'll go to Lowes today.
    I forgot to mention, I also removed the plastic coating. I used a bushing and sleeve retaining loctite on the cable. Red loctite would be better than nothing, IMO.
    Aug 2017
    Minneapolis 'Burbs
    1/8" would be a good bet.
    Loctite or similar isn't necessary on a swaged cable stop or joiner. The soft material of the fitting literally melds into the twist of the wire rope - it ain't coming off.
    (a properly done fitting is stronger than the parent cable - the cable will fail before the fitting)
    Yes on removing any vinyl coating or sleeving from the wire rope!
    Yep, done this on every car I've built using ferrules and swager from Lowes.
    Put a piece of cut off cable in the second hole so that the ferrule will clamp down tightly.
    Correct, cables are 1/8" after stripping the vinyl coating.
    Lost Wages, Nevada
    What Jeff posted is what I used on mine when I did the "Fiero" Mod. Lowes sells a "crimper" like Jeff shows for about $30 and the ferrules are a dime-a-dozen (sorta).
    Did mine about four years ago and no issues to date . . .
    Ditto on the scrape the nylon/vinyl jacket off before you crimp.
    Doc
