View Poll Results: How Screwed Am I?
Voters
17. You may not vote on this poll
  • Not so bad
    3 17.65%
  • $5,000
    5 29.41%
  • $10,000
    9 52.94%
Results 1 to 18 of 18
Thread: Damaged My Roadster, Help!
    Junior Member Justtag's Avatar
    Jan 2016
    Unhappy Damaged My Roadster, Help!
    Was enjoying some speed through the lovely Mulholland canyon and skidded into the wall. The damage doesn't seem to be too major, but with a car like this I'm unsure. The lower A-arm and body seem to have taken the worst of it. The front nose support is compressed but doesn't look terrible.
    Any ideas on how extensive repairs might be? Will I need to replace the entire nose support? It appears to be welded to the chassis.
    Appreciate any opinions on this. I'm not the builder, nor am I experienced with suspension and body repair. Looking for good shops in area from Woodland Hills to Thousand Oaks, CA.
    thanks - Justin
    I'm not having luck uploading attachments to the forum so here is a link to a photo album: https://imgur.com/a/jcpge
    Justtag,
    The control arm and suspension bits will be the easy part of the repair, but I think the body will need to come off to get at the frame damage.
    Also, I think that the body can be repaired; however, you really need one of the experts "Not Me" to assess the damage.
    Good Luck, Glad You Weren't Hurt & Please Keep Us Posted Regarding Your Repairs!
    Las Vegas, NV
    Put up the Bat Light. Batman will know what to do.
    Video
    Mar 2017
    columbus ohio
    Justin,
    I know it doesn't feel like it, but I think you dodged a bullet. From your written description I imagined far worse. It won't be inexpensive to fix if you are having the work done be a professional restomod shop, good shops are never inexpensive. If this is something you intend to tackle yourself. The body and paint part of it is going to be the most expensive. Fortunately from you pictures it looks like very modest frame damage I can't tell but it looks to me the we would have the following in it if you brought it to us:
    Body removal (if require) 6-8 hrs.
    Fabricate new front body tubes and brackets 5-10 hrs.
    Welding, finishing, & chassis paint 2.5-5 hrs.
    Body repair, glass, fill 5-8 hrs.
    paint prep./paint ??? I can't tell where the paint break would need to be, mostly because I am not sure of your color/paint and how difficult or even possible it would be to blend the paint. It is likely that you'll need to paint from the strip around to under the door. Usually you can hide a paint blend line below the door. Paint will get really expensive if you need to re-shoot color on the left side and clear the whole car.
    Re-assembly 6 hrs.
    Hope this is helpful.
    O'Fallon, MO
    If you take it to a shop and have them do everything, I don't think $10,000 is going to cover it.
    Senior Member Bren's Avatar
    Dec 2013
    Build: Sugar Land, TX; Live: Madison, WI
    From my experience with body shops that have to deal with fiberglass, I agree with rich.
    Build Blog
    #8203, carbed 427W (611 hp), TKO 600, IRS
    Delivered: May 27, 2014
    Mechanically "Complete": October 1, 2014
    Call Jeff Miller. He can fix the whole thing.
    My GUESS is you'll be in for 5K or less, IF you know the paint code and there is no frame damage..
    slpro1207's Avatar
    Moorpark, CA
    Justin, I would not take it to anywhere but to da bat. aka Jeff Miller. The pictures don’t look that bad and he will do the best job. Roll it up on a uhaul auto trailer and drive the hour and a half.
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    Justin,
    I'm not an professional builder or auto-body specialist, but grew up around both in my dad's shop. A lot has changed over the years, so pricing is something that I won't even attempt. I just wanted to add to what others have already provided regarding what looks like repairable damage. With an impact like yours, you'll want to consider the replacement of not just the LCA, but you'll also want to pay close attention to the hub, spindle, and any other critical component in the front suspension. The last thing you want in a car like these is to have a component fail at speed from damage that wasn't visible. If it were me, I'd consider replacing the full left suspension and the right shock (keep the pair matched) as part of the repair.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Jan 2016
    Really appreciate all this great info guys. Looks like I've got some bills ahead. I will reach out to Jeff to see what he thinks. The poll I made has me at 80% screwed!!
    slpro1207's Avatar
    Moorpark, CA
    If it works out with Jeff I am picking my car up there sometime in the next couple of weeks. I’m in your area and my trailer will be empty going down there. Let me know if you need to get your car down there.
    Quote Originally Posted by Justtag View Post
    80%? Not!
    You're 100% Alive & The Car Is Reparable!
    This To Shall Pass, It Didn't Come To Stay!
    Hang In There!
    # Jeff Miller AKA ...daBat.....bat phone 951-676-0191.....wow! right off the top of my head....today should be a good day....but it's early
    Super Moderator
    Ray's Avatar
    La Mesa, California
    I got clipped by a motor home while parked at a car show. Jeff did a great job and fast too!
    Ray
    Jan 2016
    Quote Originally Posted by slpro1207 View Post
    Wow what a generous offer. Thanks for that and the helpful advice. I'll let you know.
    Jan 2016
    80%? Not!
    Hang In There!
    100% TRUE! It could have been much worse.
    slpro1207's Avatar
    Moorpark, CA
    PM sent
    Cobra Driver UpstateCobraGuy's Avatar
    East Greenbush, NY
    Take a deep breath, its not that bad. You can fix most of it yourself and learn a bit in the process. Factory five can sell you the front nose support (A-frame) for around $100. I redid a wrecked Mark II with 10x's the damage and it was fine. Factory Five frames are tough and stand up to a ton of abuse. I would replace upper and lower control arms and since FFR sell them in pairs, replace both sides. Upgrade your shocks and look into doing the SAI mod since you have it all apart. Again, all things that can be done in your own garage.... Good luck!
    Mark III 4630RD Explorer 302, Holley SA570, FRPP B-cam, 4 to 4's, 3 Link, Bullitt wheels, Baer Brakes, 3.73 gears, HD T-5, I2 wiring, Koni Coilovers, Classic Gauges. Jaguar Racing Green w/ Silver stripes
    PM me if you live in Upstate New York. Get added to the "Upstate Cobras" email list. 60+ members!
