Results 1 to 9 of 9
Thread: Headlighs & Turn Signals
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Another off the wall question, I can attach the turn signal ground wire to the headlight ground wire correct?
    Alliston, Ontario, Canada
    Yes I believe you can and that’s how I did it.
    Yes, ground is ground is ground is ground is ground is ground is ground is ground is ground...
    Longmeadow, MA
    Thanks, just double checking!!
    Woodstock ,Illinois
    Ground is ground?
    Quote Originally Posted by steno View Post
    Ground is ground?
    Yes, but sometimes ground is earth.
    Senior Member 42Bfast's Avatar
    Feb 2017
    Pensacola
    Last time I fell off a ladder, ground hurt.
    Aug 2017
    Southern WV
    I added a frame grounding point to each of the lighting plugs you can never have to many frame grounds
    Rick
    mburger's Avatar
    Punta Gorda FL
    Been a long day. That made me laugh!
    Mark
