Thought I'd provide an update on my suspension adjustment. I thought I would start with simple items and surprisingly, I have a much more enjoyable ride. And, with the weather turning nice this last weekend, I am trying to add some miles. First, I verified and adjusted if necessary, tire pressure to 22 lbs all around. Next, I adjusted the double adjustable Koni shocks. I initially had them on full soft for both bump and rebound. After doing a bit of research, I decided to add 4 possitive clicks to the rebound.
As a side note, I read that you need to be careful while setting the stops full soft or full pressure, not to jam the adjustment. If you jam it, it will make it difficult to adjust in the future. I almost could not adjust one shock but got it to free up. So, I set the rebound on all to 1 click positive.
And, as I start to accumulate more miles , I believe it will get even nicer. Thanks to all for your input.
