Results 1 to 13 of 13
Thread: Radiator Color
    Radiator Color
    I ordered some Nomex grid, like WareagleScott, to protect the radiator. I was headed to the store to buy some flat black, when I wondered if aluminum color would look better. Had to buy both and wait on some suggestions. Pictures would be great.
    thanks,
    Senior Member jwebb's Avatar
    Longmeadow, MA
    thanks,
    Railroad,
    Can I ask where you got the Nomex grid?
    Jim
    Jul 2017
    I painted mine silver so it looks like the radiator.
    Chino Valley, Arizona
    Speedway sells it. My car is Ford magnetic gray and most of my trim is satin black. I powdercoated the inner mouth aluminum also satin black and painted the nomex protector the same color. Gives the mouth a dark maw - which I like for my paint scheme; thinks it really depends on the exterior look and the overall theme you are trying to achieve.
    Seasoned Citizen NAZ's Avatar
    Painted mine with aluminum rattle can paint so it matches the radiator -- a casual look and you don't even notice it there.
    Senior Member karlos's Avatar
    Littleton, CO
    Here’s what Nomex painted silver looks like (rattle can). Nomex sucks up paint like a sponge. If you decide to paint it buy at least a couple cans.
    MKIV Roadster #8641
    Complete Kit with IRS, Eaton Detroit Truetrac, 3.55 gears, Wilwood Brakes
    Ford Racing Z427 w/ Pro-M Sequential Port EFI System
    TKO 600 + McLeod Midshifter; Fast Freddie's Electro-Hydraulic power steering
    Miller Customs Bodywork & Paint
    Member cwrandolph's Avatar
    Sidney, OH
    My cover is obviously not the Nomex grid but it is silver - this is stainless mesh from Pegasus Racing.
    Quote Originally Posted by jwebb View Post
    Railroad,
    Jim
    Jim, I ordered it from Speedway here is the part number for the size I bought. I think it will need trimming, which I have read, is easily done with a box cutter.
    Nomex Honey Comb 19X26
    Part# 91734215 $ 22.99 1
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Don't forget to order the fasteners also speedway #91023108
    JR
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    I have the nomex (Speedway product) and painted it matte black.
    Later,
    Mk3.1 #7074
    Raleigh NC, OIB NC
    Black Nomex. Intake has the Mike Everson sheetmetal also painted black.
    Kevin
    MKIV #8234
    FYI I got a 4'x4' sheet of the stuff from industrial metal supply for $10. Rattle-can spray painted black:
    Longmeadow, MA
