Jman's aka "Sandman" MK4 Build Thread - Houston TX
I figured I should probably join the build thread party that this forum is, since I've already learned so much from it.
The plan is a MK4 Roadster with a Carbed 302, T-5Z and IRS. This MK4 will not have a hood scoop or roll bar and I'm still on the fence about the exhaust.
MK4 Base Kit ordered 2/17/2018 with a completion date of 4/21/2018 - arrived 5/15/2018:
Base Kit with:
Powder Coated Chassis
No body cut-outs
'15 IRS with Torsen 3.73 Differential
FFR Front tubular control arms
FFR Spindles
Wilwood Disc Brakes Front & Rear
FFR manual steering rack
FFR front & rear swaybars
Roadster Cooling Systen
Wilwood Pedal Box
Chassis Wiring Harness
Ultra-lite gauges
The engine & trans will be sourced from my 1969 Mustang Convertible, as it will go under a complete overhaul once the FFR project is complete and will receive a twin turbo Coyote motor:
302 seasoned roller block, bored to 306 with 12:1 CR
"Cam" of questionable specs
DART II iron heads
Victor Jr intake
Holley 650 Aluminum HP double pumper
T-5Z trans
https://www.youtube.com/watch?v=6BfkR71E6dA&t=68s
I am a non-conformist and I genuinely enjoy seeing vehicles that are "a little bit different", so I will probably be building my FFR a little outside the box, and the plan may take a few turns as the build progresses.
My build will not go as fast as some others as I am still holding down a full-time (plus) job, full time marriage and full time handyman on our fixer-upper home, currently remodeling a gym addition by myself, so I will post updates as they occur, however they will never be as fast as I want them to be.
FFR MK4 Delivered 5/15/2018 - First Go Cart 10/5/2019:
https://youtu.be/kPK89IgWJ0g
2015 F150 Coyote 4x4 - 2017 Shelby GT350R - 1969 Mustang Convertible - 1962 Falcon Ranchero 302/T5/3.80s
IG: @sandmans_ford_garage
