Results 1 to 10 of 10
Thread: Seating
    Member Randy's's Avatar
    Apr 2018
    NE Atlanta
    Seating
    I'm thinking ahead in my build and looking at seating. I've ordered the standard seats in leather but want to put them on adjustable tracks. I've also read in the forum that it is a good idea to elevate the front of the seat so as to provide a more comfortable driving position. I've looked around and do not see an after market product that does both. Many suggest the use of Breeze part #70602 "Installation Kit for New Steel Frame Classic Seats" which gives you the front elevation that is desirable but there are no adjustable tracks. Others recommend the Summit Racing Universal Sliding Seat Brackets, Part #SUM-G1153 that provide the adjustable tracks but do not elevate the front of the seat. Is there a solution available that does both? If not, can you mount the Summit Racing brackets on the Breeze frame? Can you use both together?
    Alliston, Ontario, Canada
    How tall are you?
    I’m 6’2”, I planned on using seat tracks and ordered them with my kit from FFR. Once I got to the seat mounting stage I decided I didn’t want to sit the aprox 1” higher the tracks would have put me, would have really screwed up my line of sight and been looking through the windshield frame.
    I'd recommend waiting until you have the seats and the car to make any decisions. Everybody is different. Some find the seats comfortable just the way they are (we do) but others like them better elevated, tilted, whatever. Regarding sliders, they're not particularly easy to install (just not alot of room to work) and many report once they're in they never move them. Even with the seats mounted as far back as they go, average drivers still don't have any trouble reaching the pedals. You may find you want and/or need them. But IMO better to decide with an actual "test drive."
    Perkasie, PA
    Good advice. I bought seat tracks with the kit and never used them. I have high back buckets for track days and it took me many hours of trial and error plus mount design to get the comfortable fit I was looking for. I am 5'9" and have the seats as low as possible and as far back as possible with a 13 degree layback angle. My line of sight is just above the steering wheel and middle of the wind screen; just where I wanted it.
    Fairfax Station VA
    I put a piece of 1" square tubing across the front mounting holes of the seat & bolted the sliders through that. You can see the bare tubing (I later painted it black) at the bottom of the picture.
    IMG_4111 by jhsitton, on Flickr
    I also mounted my sliders to 16 gauge steel so that I could easily put four bolts through the seat mounting plate on the frame.
    IMG_4113 by jhsitton, on Flickr
    After figuring out where the bolts would go, my friend CraigS welded the bolts to the 16 gauge steel. I just drop the seat into the car, line up the bolts with the holes, & secure from the underside.
    MK IV Roadster #8631
    Apr 2018
    NE Atlanta
    I am short, 5'6", on a good day. My concern is that the fix mounted seats will be too far back for me but it makes sense to wait and see. Thanks for the advice.
    Senior Member DavidW's Avatar
    Stevensville, MD
    Quote Originally Posted by Randy's View Post
    I'm only 5'10 1/2" on a good day and have the big and tall seat all the way back and wish I had more room. I can extend my legs to the end of the foot box. You should be good. Good advice to wait, they will be just sitting around until you are ready for the install.
    Member Frank Messina's Avatar
    Yorba Linda, CA
    The Breeze inclined seat mounts DO allow for re-positioning although you have to unbolt the seat to do it. Unless you are planning on having a lot of different sized people driving you'll probably never move them from all the way back.
    FFR 4440 - V8, Manual Trans, Htr, WSW, IRS. I wouldn't change a thing.
    Ohio
    The only adjustment I ever needed in mine was to possibly move the seat way back. These cars are a tight fit. I purchased the Breeze adjustable seat platforms but couldn't use them and keep my knees from hitting the underside of the dash. I'm 5'10" and could use more room but I guess these cars are meant to be this way.
    JRL16
    2bking's Avatar
    Garland, Texas
    I'm 5'6" and have the sliders on the drivers seat and elevated the front about a half inch. After driving it awhile, I never needed to adjust the seat forward and the only good the slider does is having the ability to slide the seat forward for cleaning.
    King
