0
0
Mark 4 near Gig Harbor WA?
I am looking to build a Mark IV but am concerned I may not fit (6'4" 250#). Pulled over another Cobra the other day by a different company and it was VERY hard to get in. Wondering if anyone near Gig Harbor WA has build one and would mind if I came over to see how I fit. PM me for location confidentiality. Cheers!
Good luck finding someone. Has to be some around you. Just one word of caution. There's no cookie cutter Mk4 build out there. There are many variations. You could be comfortable in one and not in another. There are multiple options for seats, seat position, pedals and pedal positions, and even mods that can be made to the footbox depending on your engine choice. Plenty of guys your size (and bigger) have worked it out. So just keep that in mind. But I completely understand you would like to see/try in person before putting down your hard earned cash.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
I remember a few builds being in the Renton and Federal Way area (well, more to to east), but there should be various ones around. Take a look through some build threads and try reaching out via PM if you don't get a response here. Most everyone is friendly from what I've found.
Gen 3 Type 65 Coupe builder
Originally Posted by
mdutton11
I’m 6’3” and fit in mine just fine. However I have sat in numerous others that I found very uncomfortable. I gaurantee you can build one and fit in it. If you try one on for size that isn’t built for a big guy it will be a completely different experience. You need to find one to sit in built by a big guy.
http://thefactoryfiveforum.com/showt...e-build-thread
Mk IV for 'Big and Tall". I had the same concerns and I did try the fit in a couple of cars here in So Cal. I'm 6'7"ish and 285ish.
First of all go with a small block Ford, this gives you room to move the side of the drivers footbox 1.5" to 2" toward the engine. When I installed the throttle pedal I reversed how the pedal and the lever attach to their pivot point, this moved the pedal at least 1" to the right. The Wilwood pedal box in the complete kit has movable faces on the pedals that can be adjusted for big feet. I still had room for a dead pedal on the left side just forward of the clutch pedal. Because I moved the right side of the footbox toward the engine it is almost even with the right side of the Transmission hump and this gives me room to lay my right leg over against it.
The second thing is seats. I ordered my kit with the Big and Tall roadster seats but they are not enough. When you order delete the seats. I used the Kirkey lowbacks
Kirkey Seats
I used the 17" and I believe those are with widest that will fit. I used the Kirkey brackets and tilted the drivers seat back a little but otherwise as low and back as far as possible.
I raised the steering wheel with spacers under the support bearing.
If you have questions send me a PM.
- You may not post replies
- You may not edit your posts
Forum Rules
