Rousch Supercharger for Coyote
Has anyone put in a Roush Supercharger in their Coyote engine? I know the power steering has to be moved over a few inches. I had to make a plate to make it work. I would love to share information with anyone who has put one in or is in the process of getting one. So far i seem to be one of the few people putting one in.
Reason: spelled wrong
Are you putting that on a stock Coyote with 11:1 compression? I think if you order a supercharged Coyote from Ford racing it is set up as 9:1? Its been a long time since I looked at that so those numbers could be wrong. Just curious.
looks great, btw.
No. It is actually the low compression aluminator engine. 9.5:1
I wanted to use pump gas. Should be a good strong engine. Im excited to get it up and running soon.
I will show people what i did when i figure everything out. I was just hoping someone else had the same setup to make sure its all hooked up correctly.
currently have one in the shop. If you email with specific questions I can shoot some pics for you.
So I have a few questions. First off, there is no brake booster with the Roadster. Do I plug off all the vacuum hoses that would go to the brake booster? On the wire harness from ford racing there is an intercooler wire. Do i use this instead of the supplied relay they sent also for the 2017 mustang? trouble getting the air filter set up just right? I ended up using a 4 inch 45 degree bend to hook it all up. Just needing a little help if anyone knows anything. I did send you a message last week Gordon. hoping to hear back from someone.
I have Gen I Coyote and harness, it does have a wire in the harness labeled intercooler pump. Not for sure this is in the Gen II harness.
I think i have it mostly wired up. He is what it looks like so far. Anyone have any thoughts on the oil separator? Are they a must for superchargers?IMG_1911.JPG
If you see the amount of oil they catch, you would say yes.
I have them on both of my supercharged cars. I have a JLT on a 13 Shelby and a home made one on a 99 Cobra with a KB supercharger.
WIS89 thanked for this post
