Thanks Thanks:  3
Likes Likes:  4
Results 1 to 18 of 18
Thread: Pin Drive knock off wheels?
    Feb 2017
    Looking to go pin drive for my wheels. Rumor has it that some states are outlawing the pin drive/knock off design. I'm in Mass. and was wondering if anyone out there knows anything about this.
    RC
    Can't help you with the legal side. But just in case you don't know, choosing to go pin drive affects more than just the wheels themselves. Because of the required adapters, the suspension width is different. For the front, requires pin drive specific suspension parts and assembly. For the rear, if you're looking at the newer style IRS, it's not even an option. Factory Five doesn't offer the current IRS in a pin drive width. Solid axle is still an option.
    Just to add to Paul's statement, you CAN order a MKIV with the older style IRS.
    Feb 2017
    I will be using a shortened solid axle rear end.
    SW Connecticut
    David,
    If you were going to order a new car (not to be raced-street cruising only), would you get a solid axle, or the older style IRS? Any opinions on how hard it would be to source a old Tbird diff, etc?
    Ken
    Did not know that! Given the improvements provided by the newer IRS, plus the parts availability, not sure there's a good reason to though. Unless you're dead set on pin drive.
  7. Thanks Bigred67 thanked for this post
    I talked to "my guy" at FFR and I'm told it's a special order item, but doable.
    Quote Originally Posted by Kennyr View Post
    David,
    Ken
    Hi Ken,
    PERSONALLY, I'd go with the older style T-Bird diff all day long if my goal is pin-drive width and 15" rims. I run that on my MKIII with absolutely no regrets.
    I looked on ebay and it seems they are getting harder to source, but you only need one and I'd have it built with new gears and a Torsen LS anyway.
  9. #8
    Pittsburgh, PA
    "Any opinions on how hard it would be to source a old Tbird diff, etc?"
    In addition to David's comments, you should be able to find one with enough calls to a junkyard. Just be careful as some of the Thunderbirds came with a smaller (7.5"?) differential. And for what it's worth, I recently saw an aluminum-case differential of the right type for sale in the "For Sale - Parts" section for a very reasonable price, with a rebuilt factory limited slip. I also have an iron case unit for sale there, for not much more than my parts costs, rebuilt with a new Detroit true-trak limited slip, and there are two "open" aluminum units in my shop that I could also live without. Good luck!
  10. Likes Derald Rice liked this post
  11. #9
    SW Connecticut
    Thanks for your response David. Since 15"s and pin drive wheels are about the only thing that I have decided on, I guess I have some thinking to do. I'm going to stop by the Factory 5 booth at Barrett Jackson tomorrow & talk to the guys....
  12. #10
    Tell my son Grant I said hello!
  13. Likes Kennyr liked this post
  14. #11
    oh, and yes, I DO love that pin drive 15" look!:
  15. Likes ChopperJustin liked this post
  16. #12
    SW Connecticut
    And a black plate too-very cool...
  17. Thanks David Hodgkins thanked for this post
  18. #13
    CobraboyDR's Avatar
    Jun 2017
    I'm sorry to be late for this.
    Really? You can get the old-style IRS which can be pin-drive? When did this begin?
    I was told the old style, T-Bird, IRS was not an option.
  19. #14
    I will call and double-check tomorrow.
  20. #15
    I made a call to FFR and got updated information from Dan:
    There was some overlap while FFR still had half-shafts but the decision has been made to NOT produce any more chassis with the Ford Thunderbird Supercoupe IRS option. Upper and lower control arms are still available as a service item but the cage is discontinued.
    FFR is also getting scattered reports of folks in certain instances being told that pin drive wheels are no longer acceptable. They do not have a list of where this push-back is happening from, but they told me that in a few instances folks are moving from pin drive to bolt-on wheels.
    Well, shoot.
  21. Thanks ChopperJustin thanked for this post
  22. #16
    On the flip side - at least in my mind - my pin-drive IRS MKIII just went up in value...
  23. #17
    CobraboyDR's Avatar
    Jun 2017
    FFR is also getting scattered reports of folks in certain instances being told that in drive wheels are no longer acceptable. They do not have a list of where this push-back is happening from, but they told me that in a few instances folks are moving from pin drive to bolt-on wheels.
    Well, shoot.
    Too bad.
    They are missing a market.
    The Pin-drive/IRS combo is the #1 reason FFR does not have my cheese. And I'll bet I am not the only one.
    Too bad an enterprising engineer doesn't offer a kit for the FFR chassis for that set-up. I'd pay decent $$$ for it.
    There is so much I really like about FFR. It's so disappointing there is no pin-drive/IRS option. Every other Cobra replica manufacturer has one.
  24. #18
    May 2016
    North of sacramento Ca.
    Maybe you could use parts from other cobra / replica to fit FFR?
