I am working on my wing mount and want some input from folks. I am not an pro engineer here so I am open to any suggestion. I attached some pics of my current set up. Ignore the hardware being used its all temp bolts and nuts for testing. Everything thing seems very solid where its at but I am sure I will need some kind of support that will attach more towards the rear of the frame. Any input? Keep support bar that goes all the way across the rear? Or should I just mount it to a small section and call it good?
^^^ Thinking I could attach to this section of the frame on each side giving a triangle shape to the whole assembly Would this be a good idea? Should I use a Rivnut or go through the whole frame with a bolt and maybe insert inside the frame? Is this a bad spot? Should I go for a more parallel mount 90Deg down to something that is more rear facing maybe attach to the back area around the trans?
