16
4
Top Notch Builder
Manual says torque the upper ball joint to 75lbs. Problem is I can’t get my torque wrench up in there. I’m using a 1/2” torque wrench from harbor freight any suggestions?
I’ll cover it more in my build thread but you can see I torqued the bottom one to 95lbs and marked the nut so I know it’s been torqued and the spec.
