0
0
Graduate 8365
Time to post the graduation of my MKIV Roaster.
First thanks to my family and particularly my wife, Leslie, for their support and encouragement throughout this build (I had to build another garage/shop to do this). I also want to thank these forum vendors Breeze, **********, Tangent, Russ Thompson, Mike Everson, FFMetals, Cobra Earl, Jeff daBat Miller and Herb Fraiser for providing great products and service in a timely fashion. Also thanks to these non-forum vendors, Fordstrokers, Summit, Jegs, Speedway Motors, McMaster-Carr and ACE Hardware. Finally, a special thanks to both forums (ffcars and Factory Five) and all the help they provide by just reading them. A special thanks to Paul Borrow (Edward) for his build threads and taking the time in answer my emails.
Finally, thanks to Factory Five for their products. I believe they are the best manufacturer for the do-it-yourself builder.
Factory Five Roadster MKIV, F5R1008365RD, delivered 1/10/2015.
IMG_2918.jpgIMG_2903.jpgIMG_1498.jpgIMG_2925.jpgIMG_1472.jpgIMG_2996.jpgIMG_3002.jpgIMG_2990.jpg
FFR Option:
Big and tall leather seats
Vintage gauges
Passenger roll bar
Wildwood brakes (6 piston front)
17 Halibrand wheels
Wind wings
Sun visors
floor mats
Drive Train:
Engine:
363 Dart SHP block (cast iron)
RPM 4340 forged crank (internally balanced)
Powerbond SFI balancer
Melling oil pump (M68)
Scat rods
Clevite 77 bearings
Wiseco 2618 forged flat pistons
GFX rings
ARP fasteners throughout engine
Fel Pro gaskets
Moroso T-style 7 quart oil pan (20533)
Moroso locking oil dip stick
TrickFlow Twisted Wedge heads 11R190 (Wiseco relief cut)
Ford Racing K351 1.6 ratio roller rockers (7/16 stud)
TrickFlow push rods
Morel hydraulic roller link bar lifters
Custom Comp Cam (lift .569 and 112 degree separation)
Edelbrock RPM Air-Gap
FiTech 30002, Fuel injection system
MSD RtR Distributor
95 amp 3G alternator (Breeze bracket)
Breeze power steering pump and bracket
Breeze 192-degree thermostat in Cobra Earl housing
GP stainless steel headers with vibe-lock bolts
Ford Racing 157 tooth steel billet flywheel
McLeod Super street pro clutch via cable clutch
Tranny:
Super Alloy T5 (Levy)
Metco driveshaft loop
Breeze shift knob
Ford Al bellhousing
Differential:
3 link, 3:55 mustang rear end with 31 spine axles
Trick flow rear end cover
Breeze lower control arms (Spohn)
Breeze 3-link QA-1 double adjustable shocks, 250lbs springs
Body:
Jeff daBat Miller paint (Mercedes Iridium Silver with Ford shadow gray stripes)
********** 289 and cobra emblems
********** air vent mesh
********** front bumper grommets
Tredwear tiring letter
FFR over-rider bumper kit
Gas-n-pipes chrome side pipes
Breeze side wedges
Drummer Mikes polished heat shields
Breeze 4 side view mirrors
FFR roll bar grommets
Everson front license plate holder
Everson windshield trim plates
Tangent fog lights (used low beam for daylight running lights)
Watson LED headlights
Interior:
competition style dash (thanks Edward/Paul)
Breeze door latch release straps
Watson tog switches
Alex glovebox and leather for dash
Shelby vinyl signature
Everson Steering column bezel
Everson e-brake handle
Everson shift ring and vinyl boot cover
Everson seat belt trim plates
********** horn button
Finsihline 289 grab handle
Carolina laser toggle rings
Cobra Roadster head rests
RT brake/clutch pedals
RT gas pedals
RT VW turn signal
FFR leather wrap steering wheel
Insulation:
Breeze coolmat rear cockpit
DEI mat and thermozite elsewhere
Misc:
Breeze free the twins bushings
Breeze offset Steering rack mounting kit
Breeze radiator shroud
Breeze radiator cover
Breeze lower radiator support
Breeze upper and lower radiator hose/tubing
Breeze engine bay battery box
Breezing locking gas cap
Breeze frame plugs
FFMetals .090 Al firewall
RT dropped trunk
Quatum 340 LPH fuel hanger with 3/8 AN fittings
QA1 ball joints
Wilwood 4 piston rear brakes, 12.2
Tires are Nitto NT555 Extreme
My Modifications:
Radiator protector stainless steel screen (Pegasus/Paul)
Dash support tubes
Dash support (bottom) (made three)
Internal firewall support
Expand passenger footbox
Removable tranny cover
Tranny cover in leather (locally)
Carpeted trunk
Battery cutoff switch (ebay)
Footwell lights
Wilwood master cylinder upgrade to .75
Power steering cooler(Edward/Paul)
Oil and water temp gauge mod to Fahrenheit
Door latch modification
Rear view mirror bracket (made)
Added passenger side footbox roll bar (like drivers side)
Transmission tunnel venting (paul/Edward)
Heated seats (Edward/paul)
Welded steel plate in drivers side footbox (deal pedal)
.080 Al driver and passenger floor panels
.080 Al passenger front footbox wall
carpet trunk
trunk light (LED) via mercury switch
Girling style brake reservoirs and stickers
Mechanical throttle (like Paul/Edward)
Kill switch .060 Al cover (engine side)
Kill switch .060 Al plate
Powder coated engine bay (local)
Powder coated small items (myself)
Sharkhide or painted most other aluminum panels
3/8 fuel lines
rear license plate mod (Kleiner)
rear bumper attachment (Kleiner)
Drivers side windshield attachment (tapped sachion)
Chrome Hand wiper from Jegs/Streetworks to pass VIN inspection
Congratulations. Georgeous work.
Very, very nice! Congratulations!
Congratulations.... from someone who is at the extreme opposite in his build (ie, I just ordered my kit). Your car looks fantastic. I'll do my best to complete mine in such a way as to at least be able to follow you on a cruise... GREAT JOB!
Congratulations From The Swampy South!
Well Done, Well Done!
