Thanks Thanks:  38
Likes Likes:  152
Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 241 to 280 of 452
Thread: Carl's 20th Anniversary #8690 - Graduated... 15,000 miles
  1. #241
    BadAsp427's Avatar
    Greeneville, TN
    Windshield Installed
    So today was windshield day... Actually it went pretty well. I actually followed a couple of other's threads and it really wasn't too bad. Below, I do not really repeat what is in those two threads so IMO it is must reading if you are getting ready to do your windshield. Espically the one from Gumball as he was very detailed in his post. I had a friend over to help me maneuver it around. So to start with, the two threads that I read, reread and then for giggles, read them again and pretty much followed to the letter.
    First one is a post from Paul (EdwardB) on another thread and I quoted it below for quick reference: CLICK HERE
    It's tight on the DS, but as long as you don't block the opening behind the dash, you can reach back in there. One tip that makes installing the windshield a whole bunch easier that I also mentioned in my last build thread. Probably one of the best tips I’ve tried in a long time. Saw it somewhere on one of the forums and tried it for the first time. Instead of just drilling out the 1/2-inch holes in the windshield side bars, drill them 27/64-inch and cut threads with a 1/2-inch x 13 tap. Easy to cut threads in the brass. That way you only have to put in a bolt from one side in each of the holes when mounting and aligning the windshield. Way easier than bolt + nut + wrench on each side while chasing around a moving windshield. When tightened, they're nice and strong. Put a nut and washer on each bolt during final assembly, but before then they hold the windshield solidly during the build.
    Second one and the most informative is from (Gumball) CLICK HERE
    The biggest thing and I have to tell you that I can not thank EdwardB enough for stressing this in his post, Tap threads into the support bars. It made the install absolutely a breeze and only took me about 30 minutes to drill and tap the 4 holes, worth EVERY MINUTE!!!!!!
    So to start off with I completed all of the prep work that is discussed in the second thread listed above. Only thing I did not have to worry about was the edge of my windshield. I found it to be smooth all the way around and not the "chipped" up look as was evident on Gumball's. I did have a couple of the mounting screws that go through the mount frame into the windshield frame that were a tad too long so I adjusted them with the bench grinder. Nothing much, just a couple seconds on each one. Then with the help of a friend, we found that the pre-cut body holes from FF were not exactly correct. So we were able to mark the actual needed area to be cut out of the body and started with that. Once we were able to actually drop the frame bars into the body cutouts, things started to take shape. I found that on the drivers side, the support bar was perfectly flat against the chassis mount. I mean, no gap, no pressure, just sitting perfect. Then I started making measurements and comparing both sides. I found that from the rear door opening, the corner closest to the seat to the bottom of the frame where it dropped into the body was exactly 32" on both sides... perfect so far.... Then I measured from that exact same point up to the top frame screw, 27 1/2" on both sides. Next I marked the holes with a sharpy, of course the passenger side is pretty simple. The Drivers side was not hard, but took a bit of feeling around to find the mounting holes to mark... Done. Good marks, pulled the windshield out removed and center punched the bars and went to the drill press to begin cutting in the 27/64" hole to prepare to tap it to the 1/2" - 13 required... Like I said, DO THIS, You will thank yourself... Next, put the frames back on the windshield (taking note to install the two shorter screws back in their proper holes) and dropped it back onto the body.
    As I said the drivers side was flat against the frame mount so it was as easy as putting a washer on the bolt and threading it in finger tight. Then on the PS I found that the bottom hole needed one thick washer and the top hole needed two thick washer to ensure there was no unneeded stress on the windshield. At least it sure seems that way. I tightened down the PS bolts finger tight and then again checked my measurements. I found I was off a bit and loosened up the bolts ever so slightly and found my centered point again with the 32" and 27 1/2" measurements. (FYI, these are my measurements, everyone's could be a bit different and if your planning to install a top, I believe the measurement is to be 27", follow the install manual for that information) Snugged down the bolts, remember, they are threaded into the support bars in the holes that I tapped out. They actually tightened up really nice. Then I was able to thread on some serrated based self locking nuts to lock everything in place. I have not yet put a lock nut on the PS Bottom bolt as the frame bar directly next to the hole is so close that I can not get a nut on the bolt.... Still trying to figure what I'm going to do there. Perhaps just some red Locktite. TBD. And there you have it, a windshield... and what a difference it makes in the look of the car...
    Sure, there was a little extra time involved in prep work, but to keep as much stress off of the windshield frame up front I hope will be worth it and prevent my windshield from cracking. Time will tell. Whooo Hoooo!
    Oh, Jeff Kleiner, you will have a little extra work to do to clean up the openings in the body where I had to open them up from the FF cutouts... Not too bad, but a little...
    Here are some photos I took along the way.
    All the parts laid out and ready. I actually was ready to use some of the spacer
    shims from the brakes if needed, but ended up not needing them at all.
    And here are the rest of the photos that I took. Again, if you have not read the above two threads, I would highly recommend you do before you install your windshield.
    IMG_3118.jpg IMG_3125.jpg IMG_3127.jpg IMG_3128.jpg IMG_3131.jpg IMG_3132.jpg IMG_3133.jpg IMG_3129.JPG
  2. #242
    .... Perhaps just some red Locktite...
    NO! Please don't!
    No problem, and not the first
    Hey B-B-Bad & J-J-Jeffski,
    Thanks for posting because I'm exactly at this point and my windshield fits the same way.
    I'm flush against the driver's side and a little off on the passenger's side which will require a couple of washers.
    Again Gents, Thanks For Posting!
    BadAsp427's Avatar
    Greeneville, TN
    NO! Please don't!
    Thought that would get your attention!
  5. #245
    BadAsp427's Avatar
    Greeneville, TN
    Doors Installed
    Today, after I dealt with the broken windshield wiper motor, I turned my attention to getting the doors hung. It was actually pretty easy and I only did a very little bit of trimming just enough to get the doors to fit. I'll leave the gap setting to the professional... Jeff K.
    I started with the PS and followed the build manual. Things went pretty smoothly. Had a little problem with the striker bolt length. It was too long due to the carpeting behind it. I easily cut it off with a hack saw after I determined the number of washers/spacers I needed. Once that was completed, the door latch was installed, again following the build manual's guide. The door is in pretty good alignment. The latch works great and latches easily with either a firm push or of course, a pull on the lever as you close it. Seems to be a nice solid close / latch.
    The DS door was a bit more difficult but went on ok. My problem with the DS is that the Striker needs to come outboard about 1/8" -1/4" further than it can. So at the moment, when the door is closed and latched, the top rear of it is actually in about 1/8" too far. I the height of the door seems good on the front and rear. the bottom of the door lined right up on the front end and I had to pull the body out a bit in front of the rear tires. I screwed the body into place from the bottom with two self tapping screws. If the door is only latched into the secondary latch position, the alignment is good. Again, I'll leave it at this point and allow Jeff K to make the proper adjustments when that time comes.
    Since I'm going to be driving in Gel Coat for awhile, I'm not extremely concerned if the fit and alignment is not perfect.
    Some photos...
    IMG_3330.JPG IMG_3327.jpg IMG_3328.jpg IMG_3331.jpg IMG_3329.JPG IMG_3333.jpg IMG_3334v1.jpg IMG_3335.jpg IMG_3337v1.jpg
  6. Likes PeteMeindl liked this post
  7. #246
    Not bad for now Carl! Did you use the laser cut spacers between the door and latch on the driver's side? The driver's side often takes two spacers &/or elongating the striker slot in the chassis to help the top of the door to meet the body...but that's just rainy day work if you're so inclined
    BadAsp427's Avatar
    Greeneville, TN
    Thanks for the information Jeff. Yes, there is one spacer there. I also used one on the passenger side. I think I may have another spacer in a box of misc parts that I received with my kit from the original owner. I'll look at that when I get out to the garage today. I'll need to pick up some longer screws as well.
  9. #248
    Elk Grove, NorCal
    Working on the interior the past few days. Carpet, Leather (vinyl fake Leather).... I asked around about ways to fill in and seal off the large hole in the side of the Trans Tunnel where the E-Brake Handle mounts. Pretty much the response was don't worry about it. Well I was just not happy with that answer as I can not believe the "stuff" would not be thrown around up under there and in time create a mess. So this is what I came up with to address the problem, at least 98% of the problem. In my next thread entry, I'm going to show my rear wall where I installed some Leather above the carpet. I state this because I have extra leather that I used for this little modification to the E-Brake opening.
    Basically, I used the E-Brake boot as a template, cute my leather so that the leather side would be towards the elements inside the trans tunnel. I cut it about 1/2" larger all the way around and found that this worked perfect. Then, I held it up in place to be sure that it was going to cover all of the opening and then marked the arc that the handle would be making so that I could cut out the slot for the handle to move within. I also drew a dotted line to indicate where I need it to fold 90* onto the floor as the opening cuts into the floor also. Once I was happy with that, I used 3M 77 Glue, same as I'm using for the carpet, and attached it to the side of the tunnel with the handle coming through the arc slot that I cut. I pushed it into the tunnel just enough so that all of the handle mechanisms were clear and not rubbing. I really think that this is going to do a great job. For me it is a bit of insurance from general debris, and heaven forbid I'm caught out in the rain, water from getting to the back side of the carpet.
    The fake leather is from JoAnne's Fabric and is the Artic Vinyl and is designed for Snowmobile Seats, good down to negitive 30*, UV protected and flame retardant.
    Here are some photos in chronological order:
    Attachment 98369 Attachment 98370 Attachment 98371 Attachment 98372 Attachment 98373 Attachment 98374 Attachment 98375
    Great idea with the e brake cover. Mind if I copy?
    Kit purchased: July 25, 2017
  10. Likes BadAsp427 liked this post
  11. #249
    Elk Grove, NorCal
    Carl
    There is so much info on this forum thatt i can’t keep up. Im glad I just came across and read through your thread. Thanks for sharing
  12. Thanks BadAsp427 thanked for this post
  13. #250
    BadAsp427's Avatar
    Greeneville, TN
    Quote Originally Posted by Vspeeds View Post
    LOL... If I said yes, I mind and you did it anyway, would I ever know...... Sure, if this helps you, please by all means use it...
  14. #251
    BadAsp427's Avatar
    Greeneville, TN
    Mirrors - Wind Wings - Sun Visor
    Today I got to install some accessories. I installed the interior and DS mirrors as well as the Sun Visors and Wind Wings. The Mirrors and Wind Wings went on just as the instructions from FFR dictated. The Sun Visors required a slight modification. According to a post from Jeff Kleiner a while ago, the small screw holes in the windshield frame get filled with chrome and thus make it very hard/impossible to install the 6-32 screws. In fact I guess that many people use metric screws. Well, I followed the post from Jeff Kleiner and purchased some square nuts and slide them into the "track" at the top of the windshield frame. This worked really well and I used a small amount of blue loctite on the screws to insure I do not have an issue in the future. So, I did have a little problem with the square nuts and sliding them in. The nuts that I got seemed to be just a little thick to slide into the track so I had to take them all to my bench grinder and just add a small bevel to the two sides that slide under the lip of the windshield frame. Once I did this, the nuts slide in just fine and everything tightened down exactly as expected.
    Here is a LINK to Jeff Kleiners thread about the sun screen mounting modification. Super Simple....
    Here are some photos.... I left the protective paper on the wind wings and sun visors for now. I did remove the paper around the screws and brackets.
    IMG_3346.JPG IMG_3347.JPG IMG_3348.JPG IMG_3350.JPG IMG_3352.jpg IMG_3362.JPG IMG_3363.JPG IMG_3355.jpg IMG_3361.jpg IMG_3358.JPG
  15. #252
    BadAsp427's Avatar
    Greeneville, TN
    133 days... So Far...
    And so 133 days ago (Aug 19th 2018) I began my Factory Five 20th Anniversary MK4 Roadster. Number 8 of 20. I had an internal mindset that I could have it completed (minus paint) by March 2019. Well other than installing my headers/side pipes that are going to be here next week and the license plate holder, I've completed well before my planned completion date. I can't wait until I get those headers and hit the road... (oh, DMV may slow things just a little bit, but not much)
    Earlier today I was just walking around and around the car; admiring all the work as well as looking for something else to do.
    I know that there will always be little things to do, but that is what rainy days are going to be for. Even though it is still up on jack stands, here are some photos of what I have accomplished in the past 133 days...
  16. Likes PeteMeindl, Drezx6r liked this post
  17. #253
    May 2018
    Park City, Utah, USA
    What a great job, Carl! Congrats on what you've built.
  18. Thanks BadAsp427 thanked for this post
  19. #254
    cv2065's Avatar
    Dec 2017
    Awesome job Carl! You certainly give inspiration that every car can have a finish line for completion. Nice work!
  20. #255
    BadAsp427's Avatar
    Greeneville, TN
    Some minor work completed
    While I'm awaiting my new headers to arrive and title from DMV I'm continuing to work on some of the little things left to do.
    Over the past few days I brushed up the aluminum cover plates for inside the trunk and installed the Fuel Tank sender unit and fuel pump covers. I'll wait to install the battery cover plate for when I'm done disconnecting the negative terminal all the time... Long time back, before I sprayed the Lizard Skin Sound control, I installed 10-32 nutserts for these panels. I will most likely finish the trunk with carpet at some point, but for now it is just the Lizard Skin and the shinny brushed aluminum. The aluminum also has 3 coats of Shark Skin on them.
    I also installed the wiring for the tag light and have also taped in place the LED strip that came with the kit as a courtesy light onto the trunk lid. There is a nice ridge that is molded into the lid of the trunk that I will permanently stick the LED strip to once the paint is completed. Until then, it is just going to be held in place with some clear tape. I'll have this light wired to the tail/tag lights. This way, when those lights are on, the trunk light will be on. I may / may not install some kind of either motion switch or simple on off switch. I really don't care if the light is on in the trunk all the time. I'm very pleased with how much that little LED strip lights up the trunk.
    I'm not sure if I posted this before, but I have also installed Red LED light strips over each foot box for the interior convenience lights. The are wired to the appropriate wire in the RF Harness and go on when you turn the headlight knob to the extreme counter clockwise position.
    Interior Lighting.JPG Christmas Present 2.JPG IMG_3420.jpg LED Trunk Light.jpg IMG_3419.jpg IMG_3421.jpg IMG_3424.jpg IMG_3505.jpg IMG_3499v1.jpg
  21. #256
    BadAsp427's Avatar
    Greeneville, TN
    Headers Installed - Gel Coat Driving Immanent
    Receive the last set of fully assembled test headers today. These are stainless steel, 3" bolt pattern headers. I'll be using these for a while to be sure that everything is just right and then in the near future I'll be receiving my final set that will be fully polished. It looks like the fit is just about perfect, only a very minor tweak needs to be done during the assembly of the final permanent set. Once completely confirmed, there will be a new option available for MK4 Builders with the BluePrint Engines 302/Aluminum Head engines. More information will be available soon.
    So for now, I've installed the side pipes and everything looks great... (The Compound 302 Polish should be here on Monday and the side pipes will be shined up and I'll hopefully get the brown off of them, waiting for amazon)
    Planning to also install some vinyl striping to the body to add some jazz to it until it gets sent off to Jeff K next fall.
    I've sent all the papers in to the DMV for the title and am just in the waiting stage for that....
    Driver's side:
    Passenger's side:
    Final Set of Test Headers:
  22. Likes PeteMeindl liked this post
  23. #257
    BadAsp427's Avatar
    Greeneville, TN
    Who Knew Gel Coat Could Look So Good!
    Ok, exhaust system installed and it's down on all fours.... Today I rolled this thing out of the garage and took some photos... Then took it for a drive around the neighborhood. I would have put 100 miles on it if I could have. I settled for about 3. My next step is to get the alignment completed professionally and hope for the DMV Title/Registration this week. I did not want to tear up the tires or get a ticket. So for now, just a big grin. Who knew Gel Coat could look so good!!!
    IMG_3572.jpg IMG_3575.jpg IMG_3577.jpg IMG_3582.jpg IMG_3584.jpg IMG_3586.jpg IMG_3581.jpg IMG_3580.jpg
  24. #258
    Oct 2014
    Vermilion, OH
    Looks great!
    CVOBill
  25. #259
    Carl-
    She looks great! Nicely done. So, are we going to run a pool to see how many miles you put on her between now and when you send her to Jeff for paint?
    I agree with you that she looks great in gel coat. I may be doing the same thing as you. I think it makes sense to drive in gel coat, just as a shake down period.
    Congratulations on a terrific job!
    BadAsp427's Avatar
    Greeneville, TN
    Carl-
    I guess that would mean I would have to hook up the GPS Speedo... Shhhhhh :-}
  27. #261
    Nov 2012
    Tacoma, WA
    Great job on getting her done. You made quick work of it. I bet you will put a lot of miles on her over the summer before paint. I was in gel coat legally driving for two months before sending off to paint. Put 500 miles on mine and that was just driving (long way) to work a few times and short spirited drives.
  28. Likes BadAsp427 liked this post
  29. #262
    Senior Member VAHokie's Avatar
    Chantilly, VA
    Nice work, Carl. To think you just received the car 5 months ago and are already done (are they ever really, though?!?) is truly impressive. If you feel inclined to stretch her legs a bit when you're legit, drive on up to NoVA - there's a few of us up here just getting started. Congrats on hitting this milestone!
    MKIV Complete Kit #9494 l Delivered 1/5/19 l First Start 11/28/20 l First Go-kart 4/11/21 l Carb'd 347 l Mid-shift TKO600 l 3.55 IRS l P/S l Forte Mechanical Throttle Linkage l RT Turn Signal, Drop Trunk l Breeze Upper/Lower Radiator Support, Fan Shroud l Boig Upper/Lower Cool Tubes & Quiet Pipes l 18" FFR Gasser Wheels l Build Thread
  30. Likes BadAsp427 liked this post
  31. #263
    Nearly All Of Us Will Eventually Find Out The Joy Of Gel Coat!
    Congratulation From The Who-Dat Nation!
  32. Likes BadAsp427 liked this post
  33. #264
    BadAsp427's Avatar
    Greeneville, TN
    Gel Coat Driver - WINNER
    Today was what I can really call my first day out with the roadster. Sure, I've done a couple 2-4 mile drives around my immediate neighborhood, but today, I put 40 miles on the car. LOVED every second of it. I was able to get a good feel for the car and test out the heated seats, heater and the cruise control. All works well. The cruise control does need one minor setting change on the gain and it should be good to go.
    Then I finished out the night by taking the car to a Cruise In at the Sonic in Monks Corner, SC. This was hosted by the Low Country Muscle Car club. They have their "Ride of the Month" gathering every 3rd Saturday and the staff at the Sonic pick their favorite car and crown it the "Ride of the Month". You guessed it, Factory Five Roadster #8690 took home the honors on her maiden trip out of the Cobra Cabana where it's been being built for the past 5 months.
    Oh, and I can not confirm or deny the accuracy of the "Memory" on my spedo from one of my fun drives today on some back country road here in the SC low country... Now if I could only get the DMV to send me a title and registration, I would not have to look in my mirror so much.....
  34. Likes Higgybulin liked this post
  35. #265
    Congrats, Carl! I can't wait to get mine out on the open road.
  36. Thanks BadAsp427 thanked for this post
  37. #266
    May 2018
    That's great, Carl! Awesome! Congratulations.
  38. #267
    RR20AC's Avatar
    Puyallup/WA
    Great job in the first five months Carl. I’m sure you’ll get many more before fall when it goes off to paint. Congrats. These are very fun cars. Did you decide on a color? Jim
  39. Thanks BadAsp427 thanked for this post
  40. #268
    cv2065's Avatar
    Dec 2017
    Looking good Carl! Next award you win make sure you are wearing “the hat” ��
  41. Thanks BadAsp427 thanked for this post
  42. #269
    BadAsp427's Avatar
    Greeneville, TN
    Quote Originally Posted by RR20AC View Post
    All I know at this point is it will be a red with gray stripe. I'm looking at different reds, and so far the Mazda Soul Red Crystal it getting my vote and some kind of a darker gray... Time will tell as well as $$$
  43. #270
    Chantilly, VA
    Congrats, Carl. The first of many awards I'm sure.
  44. Thanks BadAsp427 thanked for this post
  45. #271
    Nov 2012
    Tacoma, WA
    Congratulations you made quick work of your build!
  46. Thanks BadAsp427 thanked for this post
  47. #272
    BadAsp427's Avatar
    Greeneville, TN
    Headlights dim
    The other night I was adjusting my headlights and realized that the passenger side was significantly dimmer than the drivers side. I remember as I was building things and running the wiring that one side or the other of the RF harness had a smaller gauge wire going to the headlights. I'm guessing it is the passenger side. Has anyone had this same type of issue? I've not had the chance to get under the body and actually look at the wiring yet. I was also going to swap the headlight bulbs just to be sure it is not the headlight itself.
  48. #273
    Betcha it'll be a ground issue.
    BadAsp427's Avatar
    Greeneville, TN
    Yes, I'm going to be looking at that as well..
  50. #275
    BadAsp427's Avatar
    Greeneville, TN
    Headlight Problem found - Bad Headlight
    Today I had a chance to do a little trouble shooting and here is what I found out. First thing I did was check my weather pack connections, just wiggled them around a bit to see if that was the problem. No change, the passenger side light was still dim. I also double checked to be sure that both of the bulbs had both low and high beams working. They did. So next, I just swapped out the two bulbs. The bulb that was dim on the PS was also dim on the DS and the other one was just as bright as before... So there is my problem, the bulb is bad... So next I looked at them for the part numbers...
    This photo shows what both have on them, they are both marked as exactly the same.
    But take a look at the actual Halogen bulbs inside the headlights. The one with the "blue" coloring is the dim bulb and the clear one is the one that is bright. It's like when the bulb assembly was put together, the person doing it grabbed the wrong bulb to install. So I guess it's just going to be the purchase of a new headlight fixture to fix the problem. Fingers crossed that is all it will take.
    Dim Bulb
    Bright Bulb
  51. #276
    cv2065's Avatar
    Dec 2017
    Glad it was that simple Carl!
  52. #277
    BadAsp427's Avatar
    Greeneville, TN
    Went out the other night and bought a pair of Sylvania H6024 Silver Star Halogen headlights. Tonight was the first chance I had to pull the car out and adjust them. Man, these are bright and right. I also took the car around the block a couple times checking the high beams/low beams and they really seem to be good. Oh, and I may have,.... no,,,, I did romp on it with the intent to break loose the rear tires.... easy... No Problem!!! Good times... Now, if SC will just send me a title.... Ugh...
  53. #278
    Carl,
    You passed up a good reason to convert to H4 bulbs! Glad you resolved the issue.
  54. #279
    BadAsp427's Avatar
    Greeneville, TN
    1st Extended Drive - Out of my immediate neighborhood.
    Let me start out by saying that I fully understand and agree with everyone about the use of the full seat belt harness installed in my roadster. I'm a guy that ALWAYS wears his seat belt in my DD and expect everyone in my car to do the same. On this day described below I was originally planning to take my friend around the block. In my neighborhood, this is about 1 mile of driving; not over 35-40 MPH max and on a very low traveled road. But just after leaving the driveway, the plan changed and I went ahead and drove a bit further. My mistake was not putting on the full harness in the first place, and my second was not stopping and putting them on once I changed my mind to go a bit further. Please, if you are reading this or watching my video know that it is never OK to drive this type of vehicle without the use of a full restraint system. I want to also thank the few that called me out on this.
    So about a week ago I had the chance to take the cobra out for a bit of an extended run. This was the same day that I had taken it out to the little cruise in where I won the "car of the month" award.... Here is a video of about an 18 mile "leisurely" drive. I was really trying to get a feel for the steering and the cruise control. The Cruise Control is still not reacting just right, but I'm certain it is just adjustments on the "dip" switches. The steering seems really ok, I'm still wondering about the self centering, but as I drive it, it seems really reactive and right. Perhaps it's just me and I need to get use to the different feel from my front wheel drive focus. Time will tell.
  55. #280
    Thats pretty cool. Nice video. Cant wait till I catch up to ya. But I gotta say... no shoulder belts?!?! There isnt 1 thing I wanna smack my face on in that car.
