Thanks Thanks:  10
Results 1 to 32 of 32
Thread: Battery location options
    Is there anyone here who has done the battery box from FFmetal.com? It looks clean, but I'm envisioning REMOVING the battery to replace after the body is on, and wondering how much of a pain in the *** that might be.
    Looking for other options / experience from others.
    Saleen
    Dec 2017
    Southern Ontario
    Yama-bro just did this not too long ago. Full pics on the install in is build thread
    https://thefactoryfiveforum.com/show...light=yama-bro
    Post #263 I think it was
    Higgy
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
  3. Thanks Saleen9165 thanked for this post
    Likes Yama-Bro liked this post
    Alliston, Ontario, Canada
    I used the forward mount from breeze and am very happy with it, highly recommended. Moves the weight to a better spot and easy to access. Much easier to disconnect negative for working on the car too.
    I know many of the pro builders on here use it on ever build.
  5. Thanks Saleen9165 thanked for this post
  6. #4
    RJD's Avatar
    Northern Virginia
    Love my front battery box from Breeze. Easy to get to and no need to run a battery cable all the way from the back of the car.
  7. Thanks Saleen9165 thanked for this post
  8. #5
    Heart of Dixie, Alabama
    I am still in the build process, but did install the rear battery box. I am thinking a battery swap will be a test of strength and caution. I have the drop trunk box, so no place to put your knees in reaching the battery, which will have to be raised under the arched 3/4" hoop, avoiding hitting the terminals against the metal. With arms fully extended you will need to lift the battery, just clear of the box and draw toward yourself. I have not practiced the procedure, just tried to think it out, before it is needed.
  9. Thanks Saleen9165 thanked for this post
  10. #6
    Copperhill, TN
    Another vote for the Breeze front mount, shorted cable runs, easier to get to, works great.
  11. Thanks Saleen9165 thanked for this post
  12. #7
    Jun 2015
    Fairfax Station VA
    Add me to the number of Breeze advocates. Great product, superior customer service, and excellent instructions; you can't go wrong!
    MK IV Roadster #8631
  13. Thanks Saleen9165 thanked for this post
  14. #8
    # whatever Breeze
  15. Thanks Saleen9165 thanked for this post
  16. #9
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Breeze also, Mark is great to work with.
    JR
  17. Thanks Saleen9165 thanked for this post
  18. #10
    I used the trunk drop battery box. It is not easy to remove the battery with the body on but it is not a big deal. Not something I plan on doing very often. I like it. Extra room in the trunk and a clean engine compartment. Just a matter of personal preference.
  19. Thanks Saleen9165 thanked for this post
  20. #11
    Senior Member cv2065's Avatar
    Dec 2017
    I’ll be going with the Breeze front mount. From what I’ve read, you can’t use the FFMetal rear battery box in recent MKIV frames.
  21. Thanks Saleen9165 thanked for this post
  22. #12
    Well, it looks like I'll be going with the front battery box then. Thanks to everyone for the recommendations.
  23. #13
    Senior Member TBull's Avatar
    Dec 2011
    St. Louis
    Does anyone know if you have an older MK4, does the FFMetal battery box interfere with maintenance or removal of the IRS center section? Thanks
  24. #14
    O'Fallon, MO
    Yes Dan it is a problem with the new IRS. There may be a work around
    Well it may fit better than I thought
  25. #15
    Jax Beach, FL
    These cars need the weight in the rear if you plan on doing any performance driving.
    Ease of access is a once in maybe 7 year concern. 20,000 miles and I have never touched my battery. I have, however, wished for more traction in the rear.
  26. #16
    Kirkland, WA
    To safe the battery for removal from a trunk well, would be fairly easy to 3D print terminal caps with (plastic or nylon) set screws.
    Mk4 #8861 Complete kit. Delivered: 27 Apr 2016, currently a roller.
    Gen-2 Coyote, clutch, TKO600, midshift, and solid axle from Forte. Many pieces from Breeze and Replicarparts.
  27. #17
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    I have the new IRS frame.
    Working on a custom drop box to put two 6V batteries in series (following FFMetal's lead). Will let you know how it goes (once complete …)
    Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
  28. #18
    Raleigh NC, OIB NC
    Have a red top battery in a CNC bottom mounting plate in the trunk. Very easy to remove or hook charger leads too.
    Kevin
    MKIV #8234
  29. #19
    May 2018
    Merritt Island, FL
    Quote Originally Posted by initiator View Post
    Or use blue tape.
  30. #20
    Kirkland, WA
    That wouldn't be nearly as much fun, would it? I've arced through blue tape on impact, but several layers should do the trick.
  31. #21
    Jax Beach, FL
    How about electrical tape? Hence the name, blue tape is masking tape. Not exactly made for insulation. Or save the plastic caps that come on the battery when you buy it?
  32. #22
    Richard Oben's Avatar
    Kansas City MO
    FFmetal box in a fairly new mk 4 works great. We have done the FF metal boxes for years. Breeze is great but the front can get crowded. JMHO. Richard.
  33. #23
    Senior Member DavidW's Avatar
    Stevensville, MD
    The battery in the trunk is the ideal place for me, a battery just doesn't look right under the hood. Use the red optima battery with the side terminals in the trunk installed as the build instructions mention and upgrade from the FFR 4 gauge wire to a 0 gauge wire. I don't see any reason to have constant access to the battery... if you need a trickle charger a permanent trunk mount would be ideal.
  34. #24
    Aug 2012
    Grand Rapids, MI
    This may or may not help.
    My plan for my MK IV Challenge Car build with 2015 IRS is to put a Braille B3121 below the upper trunk level, behind and to the passenger side of the diff center. From my evaluation a dedicated box and battery just fits. It should lift straight up even with the additional cross bar for the Challenge Car. I would like the weight lower but the 21# Braille would be only about 10-12" above the axles. From this location the battery cable is about 8' long.
    Jim
  35. #25
    Junior Member BULLITT428's Avatar
    North Vancouver Canada
    I used the battery box from FFmetal.com I was very impressed at how easy it was to install and the fit up and look were great!! I wanted the weight in the rear for performance driving.
    Ed.
    FFR 7570, 402sr ROUSH 455HP, TKO 5 speed, Wilwood brakes, IRS 327gears Torsen Diff, Forte's Hydraulic Clutch, 15to1 AGR Power steering rack and lots more it never seems to end?
    TEMPTATION: because willpower is no match for Horsepower!
  36. #26
    Quote Originally Posted by BULLITT428 View Post
    Ed.
    In my post, I listed my concerns, but am pleased with the product. I have the FFM box mounted up and look forward to having the battery in the rear and not taking up space, otherwise. The box is very well designed and made. I am lugging up my cable ends and wiring in the cut off switch, presently.
  37. #27
    Bill_VA's Avatar
    Manassas, VA
    14 years ago, I bought everything that FFmetal (Linwood) had; firewall forward, larger footboxes, F-panel without a hole, radiator shroud, and the battery box. Now I are FFmetal! I've only had to get to my battery twice in 14 years. The key is using remote battery terminals and a cutoff switch. Hint, leave the battery handle on, makes it easier to pull it out of the box.
    Non-donor - Engine Factory 351w/400hp - TKO500 - 3-Link - Cobra brakes - FFmetal - Wilwood pedals - FR500 wheels - NCPainter
    Owner of FFmetal.com
  38. #28
    Feb 2017
    Kansas City, MO
    I also have the IRS and wanted a rear battery location, so I had a friend weld up a box for me with 2 Optima 6v in series. Here is what it looks like.
  39. #29
    Nov 2016
    "The i.e." SoCal
    We made room for a small AGM battery in the wheel well of this MK4. Way easy to get to and out of the way.
    2017-07-16_09-59-46 by Frank Maslowski, on Flickr
  40. #30
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    I just wasn't a big fan of the rear battery myself. So...
    Some steel, a neighbors welder, bit of paint, thread tap and some large body-bolts from TSC. Made my own front battery box for pennies.
    2016 MK4 | '99 Explorer 5.0 | E303&600cfm carb | T5z + 3.55 | 3-link | SN95 | PB/PS | FR500 17" 315&275 |
  41. #31
    Cape Coral, FL
    Well, I went with both. I have the Breeze front battery mount for the battery and also purchased the FF Metals drop box for the truck since they are so small. I hate to have the wasted space under the top shelf of the trunk. I have the Moser 3 link so no issue with the IRS cross member. I'm using the FF Metals drop box as my tool/extra parts storage compartment in my trunk. Got a flocking kit from Flockit.com and the FF Metals box looks beautiful.
    A bit pricey but I think worth the extra storage space in the trunk.
  42. #32
    Jun 2015
    Fairfax Station VA
    Both Mark and Bill do nice work, don't they. Can't go wrong with either.
