Thread: What length flex line for hydraulic clutch and Coyote/Tremec?
    Feb 2018
    Frisco, TX
    I want to go ahead and run my flex line for my clutch before I drop the motor in. Does anyone know what the ideal length is for use with Coyote and Tremec? I am going to just run it over, out the side of the upper panel on the DS footbox, and then down to the bell housing. I'm thinking this 24" may be long enough, considering I have about 8" of flex line coming out of the bell housing from my hydraulic release bearing.
    https://www.summitracing.com/parts/aaf-all46100-24
    What do you think?
    Senior Member Jdav's Avatar
    ATL GA
    What do you think?
    I don't recall the length, but if you are getting Forte's hydraulic clutch he'll send you the line as well.
    MK4 #9028 - Coyote - TKO600
    Feb 2018
    Frisco, TX
    Thanks for the reply. I bought a Tilton hydraulic release bearing and it didn't come with anything to connect to the master. I ordered the 24", if it is too short I'll exchange for the 36", but I think it will work.
    Richard Oben's Avatar
    Kansas City MO
    Go 36, R
