Thanks Thanks:  2
Results 1 to 7 of 7
Thread: Steering wheel horn button/center section
    Prairieville, Louisiana
    If I wanted to replace it (I like the wheel that comes with the kit, but hate the center), what would I be looking for? Grant horn button or ididit horn? What key words to I need to search? Or is it proprietary?
    I want more color. Maybe a ford oval on a chromed background?
    '33 Hot Rod
    MK4 Roadster
    Oct 2014
    Vermilion, OH
    I bought a Momo horn button, that was the only that I could find that matched the bolt circle on the steering wheel.
    CVOBill
  3. Thanks pbrew thanked for this post
    It bolted up? The FFR one just pushes in using an o ring to hold it. Can you link yours?
    '33 Hot Rod
    MK4 Roadster
  5. Thanks pbrew thanked for this post
  6. #4
    Oct 2014
    Vermilion, OH
    My car didn't have a horn button,just the push in FFR center. I like the look but I wanted a horn button instead. I got the button from Mrsteeringwheel.com and if I remember correctly you will need the retaining ring.
    http://www.mrsteeringwheel.com/momo-...-out-of-stock/
    http://www.mrsteeringwheel.com/momo-...ng-ring-plate/
    CVOBill
  7. #5
    I’ll check that it. Thanks Mr Bill.
    '33 Hot Rod
    MK4 Roadster
  8. #6
    Folsom, CA
    anyone have pics of this setup? can you use the FFR wheel?
    Todd
  9. #7
    Here is what I did with mine, it just takes a bit of machining if you have access to a lathe.horn buttonII.jpg
