Results 1 to 3 of 3
Thread: EFI wirers?
    Junior Member BULLITT428's Avatar
    North Vancouver Canada
    EFI wirers?
    I'm running a carb not an EFI and I have an AL-6 MSD box and a MSD distributor. I have two wires with the Ron Francis wiring harness orange and blue that are for an EFI. Should I run the orange one to the coil or is this necessary.
    Thanks ED.
    FFR 7570, 402sr ROUSH 455HP, TKO 5 speed, Wilwood brakes, IRS 327gears Torsen Diff, Forte's Hydraulic Clutch, 15to1 AGR Power steering rack and lots more it never seems to end?
    TEMPTATION: because willpower is no match for Horsepower!
    The orange wire in the RF EFI bundle is simply a switched 12v wire. If you need one for your MSD components or coil, use it or use it for any other 12v switched need.
  3. Thanks BULLITT428 thanked for this post
    Fairfax Station VA
    Light blue wire is +12V ONLY at ignition. Good for triggering a latching relay, but generally not used for carb.
    MK IV Roadster #8631
