Likes Likes:  2
Results 1 to 18 of 18
Thread: Electric Power Steering...Another Convert!
    Senior Member frankb's Avatar
    Feb 2014
    Marana, AZ
    So, after reading several threads by guys who did this conversion, and after deciding that I'm too old and weak to drive one of these with manual steering, I decided to dive in. As have others, I adapted the Saturn Vue electric power steering unit to FFR #8317, completing the installation last week. I built the bracket from 3" wide by 1/8" thk steel (from Home Depot), but rather than just attaching to the lower 3/4" square tubing, I attached it to both the upper and lower tubes. I used 1/4" rivnuts in both tubes to make the attachment. I also sourced a few of the adapters from E-Power Steering (www.epowersteering.com) as well as their "advanced" adjustable controller that allows the steering assist to be adjusted from 0 - lots. (Note that E Power Steering offers complete kits that include the power steering unit to make this conversion.) The results? WOW! I have been driving with the controller set to "min" and love the way the car drives! No more tired arms!
    I have attached a few photos for your information.
  2. Likes FlyingCobra liked this post
    Excellent results. In addition to PS making things easier, I think it also offers a safety factor. The times I had manual what I noticed was I would often need to plan ahead in a parking lot or in my neighborhood. I worried that some kid w/ a ball, or grandma w/ a shopping cart, might pop in front of me and I simply would not have the strength to do what I needed to avoid.
    Senior Member Mike N's Avatar
    Mooresville NC
    Very clean install. Nice work!
    Mike............
    Mark Dougherty's Avatar
    Hershey PA
    Also a huge fan here
    The traveling Builder
    717-773-5624
    Rhode Island
    frankb, You did a very nice installation. I'm assuming that this method still uses the manual steering rack. Does it also keep the front end alignment specs for manual steering?
    BigUgly
    FFR 6760 Mk 3.1 Fortes Dart 427 TKO 600 3.55 3 Link Solid Axle
    Member FlyingCobra's Avatar
    I'm planning on this for my car. I'm going for a "pure" car, and power steering technically reduces that some, but the fact that I can set the exact amount of assist that I want (and that my wife can do the same - I expect her level will be different) makes it seem like a no-brainer to me.
    Not sure if I'm going to put in a stereo, though.
    Feb 2014
    Marana, AZ
    BigUgly:
    This installation does retain the manual steering rack. I have not had the alignment adjusted yet, so it still retains the manual alignment. It is just a wee bit twitchy at highway speeds, but not uncontrollable or uncomfortable (scary), so I will eventually get around to adjusting the alignment to include more caster. This should make the straight-line steering more stable. The work is worth it, as the car is much more comfortable to drive!
    BTW: Thanks to both you and Mike N for the compliment!
    Frank B
  9. #8
    Quote Originally Posted by FlyingCobra View Post
    Here's another place it can go - stealth / cheap / clean engine compartment...
    https://thefactoryfiveforum.com/show...ll-A-Part-EPAS
  10. #9
    Making it up as I go. JJ in Cbus's Avatar
    Columbus, Ohio
    Frank, did you use a salvaged unit or did you buy one new? This is a project I am planning on doing this winter and trying to get all my parts together before the body comes off. BTW thanks for the epowersteering link.
    jj
  11. #10
    Feb 2014
    Marana, AZ
    JJ:
    I went to the local Pick-a-Part and got one from a 2007 Saturn Vue. If you go this route, be sure you get one from the Saturn Vue or Chevy Equinox. The ECU on the unit must be the one with the steel cover. The controllers that are available (in my case, from E-power Steering) only work with the steel box ECUs. When I grabbed my power unit, I also grabbed the mating splined slider for the power unit's input shaft. This is how I adapted the FFR steering rod to the input shaft of the power unit.
    Frank B
  12. #11
    I already have that thread bookmarked for when the time comes. It's what I was planning on doing.
  13. #12
    Dec 2013
    Sandia Park, NM
    Quote Originally Posted by frankb View Post
    Frank,
    I just came across this thread - a little late but better late than never!!
    Like FlyingCobra and others, I plan on doing this mod for my MK4. Rather than going the Pick-a-Part route, I'd like to get the parts from E-Power Steering. I have some questions.
    Does the "Straight Kit" for $655 look like it will work? It has the tube and the adjustment knob. What couplers did you get from them? The ones that come with the kit or others? Looks like the advanced EPS controller comes with the kit.
    Thanks!!
  14. #13
    Junior Member Tacojoe's Avatar
    Mar 2019
    I'm late to the party here- what a great idea! Nice job!
  15. #14
    Feb 2014
    Marana, AZ
    Swwebb: The parts I ordered are - 16.5mm to 3/4" coupler, Dust boot, and the Advanced EPS Controller. When I grabbed the drive unit from the Pick - A - Part, I grabbed the mating slider for the input spline.
    The "Straight Kit" to which you refer has some parts you won't need and also does not have the bracket to mount the drive unit to the frame. I know that they have a complete kit for our FFR Mk4, but it is not listed. Give them a call. Otherwise, you may wish to build your own bracket and purchase the "Universal Kit".
  16. Thanks swwebb thanked for this post
  17. #15
    Feb 2014
    Marana, AZ
    Thanks, Joe!
  18. #16
    Dec 2013
    Sandia Park, NM
    Great!! Thanks for the detailed info!!
    Edit 4/12 - MK4-specific kit is $650.
  19. Likes toadster liked this post
  20. #17
    Jan 2020
    Northville, MI
    Enjoyed the information from this post. FYI: The price for the "Factory Five MK3/4 Roadster Kit" from epowersteering.com is $745.00 as of 2/3/2020.
  21. #18
    Folsom, CA
    Quote Originally Posted by E-Car Man View Post
    I just bought the epowersteering kit for FFR for $650 last month - was there a change in the kit? maybe I got lucky with the old price?
    https://epowersteering.com/purchase/product/factoryfivemk4
    Todd
