Replacing wheel studs
I am using 25 mm Eibach spacers (90.4.25.010.3) on the rear hubs with the IRS. I was planning not to change the bolts on the hub but use the original Ford ones. The less I do, the less can go wrong.
I will then need some Mustang lug nuts that will fit the spacer. Does anyone know the thread size?
