Results 1 to 17 of 17
Thread: Replacing wheel studs
    Mar 2017
    Norway / Merritt Island FL
    I am using 25 mm Eibach spacers (90.4.25.010.3) on the rear hubs with the IRS. I was planning not to change the bolts on the hub but use the original Ford ones. The less I do, the less can go wrong.
    I will then need some Mustang lug nuts that will fit the spacer. Does anyone know the thread size?
    The 2015+ Mustang studs are 14mm x 1.50. It's kind of a mixed bag though. The Eibach 90.4.25.010.3 spacers come with previous Mustang 1/2 x 20 studs and nuts to bolt onto your hubs. So you'll obviously need 14mm x 1.50 nuts to retain the stock metric studs. But the nuts that come with the Eibach spacers are not exactly like standard lug nuts. They're lower profile. I thought about mixing and matching like this on mine, but decided it was simpler just to replace the studs. It's not that hard.
    Mar 2017
    My idea did not work. I ordered a set M14 1,5 Ford Performance Parts Wheel Nuts, M-1012-N. The nuts came out approx. 5 mm above the wheel-mounting flange of the spacer. Consequently, I was not able to install the wheels. Replacing the studs worked like a charm.
    Top Notch Builder P100DHG's Avatar
    Pasadena, CA
    what studs did you end up ording?
    Mar 2017
    Quote Originally Posted by P100DHG View Post
    I used the ones that came with the kit as described in the manual
    Mar 2017
    I wanted to use the original studs, M14, as delivered on the hubs. When I used appropriate Ford nuts the nuts themselves came outside the mounting surface for the wheel on the spacer. I replaced the studs on the hubs with the ones that came with the kit. They had to be shortened by approximately 15 -20 mm. Installing the brake rotor and spacer with the supplied nuts made a perfect fit. The wheels uses the studs installed on the spacer. The spacers need to be used to clear the rear Wilwood calipers and 17" wheels
    Pasadena, CA
    Sorry I have to clear up some confusion I have.
    1a. The studs that come with the wilwood rotors, do those have to be trimmed or replaced with shorter studs?
    1b. If they do need to be replaced what is the appropriate size
    2. I understand that the newer mustangs and now consequently the FFR cars come with a metric stud. With regard to the EBtech spacer listed above which comes with a standard thread my understanding is you opted to keep the 1/2” thread. So the front and rear of your car have different size lug nuts?
    3. Looking at the Eibach spacer I can see what Edwardb is talking about that they came with a low profile lug nut, did you keep or replace the lug nuts it came with?
    My main concern is #1 I don’t care if I have different size lug nuts and studs and long as it’s safe. Links or pics would be appreciated
    Pasadena, CA
    I also just found these so that might solve some problems What do you guys think?
    Eibach S90-4-25-063-B
    https://www.americanmuscle.com/eibac...cers-2015.html
    I spoke to American muscle these have “good potential to be on sale on Black Friday”
    Mar 2017
    1a. The studs that come with the wilwood rotors, do those have to be trimmed or replaced with shorter studs? There are no studs on the Wilwood rotors. The studs that needs to be replaced are on the FF delivered hubs used on the irs suspension.
    1b. If they do need to be replaced what is the appropriate size. They need to be replaced with the FF supplied studs, 1/2 -20. They are however, somewhat to long and needs to be shortened by approximately 15 - 20 mm.
    2. I understand that the newer mustangs and now consequently the FFR cars come with a metric stud. With regard to the EBtech spacer listed above which comes with a standard thread my understanding is you opted to keep the 1/2” thread. So the front and rear of your car have different size lug nuts? The front hubs come with 1/2 -20 threads as does the rear spacers. The front and rear lug nuts as supplied with the wheels, are the same.
    3. Looking at the Eibach spacer I can see what Edwardb is talking about that they came with a low profile lug nut, did you keep or replace the lug nuts it came with? All parts used come with the FF kit and the spacers.
    My main concern is #1 I don’t care if I have different size lug nuts and studs and long as it’s safe. Links or pics would be appreciated.
    See comments above. I will look and see if I have some pictures of this. Give me a few hours
  10. Thanks P100DHG thanked for this post
  11. #10
    Mar 2017
    You will then end up with different front and rear studs. Eibach 90.4.25.010.3 are similar but with the 1/2" studs as used on the front. Most likely also on sale
  12. #11
    Mar 2017
    I found two pictures. One with the hub with the M14 studs and one with some of the shortend 1/2" stus installed, no nuts, brake disc and the spacer
  13. #12
    Pasadena, CA
    Thank you for bearing with me. My kit doesn’t come till January but why not take advantage of a sale now. Thank you!
    I understand now.
  14. #13
    Pasadena, CA
    Sorry it’s not specified in the manual but I am assuming that the front FFR supplied 1/2” studs and that page 119 of the manual is removing the stock metric studs and replacing the with 1/2” studs is that correct?
  15. #14
    Mar 2017
    Correct
  16. #15
    Pasadena, CA
    So I went ahead and order these (wasn’t going on sale through speedway unless I spent $250 or more)
    https://www.speedwaymotors.com/Eibac...rd,324913.html
    Speedway says they include shorter 1/2” studs for the rotors. Hopefully everything marries together nicely.
  17. #16
    Pasadena, CA
    The kit didn’t come with the shortened studs. Speedway was kind enough to offer a credit toward shorter studs. I found these
    https://www.amazon.com/gp/aw/d/B000C...KIKX0DER&psc=1
    Any impressions before I order?
  18. #17
    If you can get the shorter studs included with the wheel spacers, and you haven't already changed to the kit provided SAE studs. Should work. Otherwise, a cut-off wheel makes short work of the kit provided studs once they're installed. Simple fix.
