Likes Likes:  14
Results 41 to 80 of 82
Thread: Driveshaft Loop
    Jeez Rich, need stronger meds? I think this is an interesting discussion.
    Jeez CraigS, EVER HEARD of sarcastic humor?
    Bakersfield, CA
    Quote Originally Posted by miller7448 View Post
    Has anyone priced out a carbon fiber drive shaft?
    https://www.hotrod.com/articles/the-...afts-from-qa1/
    In my early drag racing days I broke a lot of u-joints on the 1-2 shift close to 9 grand. Never twisted a driveshaft. Don’t think I ever saw one twist, it’s always been joints, u-bolts or yokes. IMHO I think twisting one our length shafts would be REALLY hard to do.
    $600-$1000 carbon fiber driveshaft.... bragging rights?
    $130 driveshaft loop (saved my butt many times 40 years ago)..... definite no brainer.
    Kurt
    Then of course line your transmission tunnel with old tiles from the space shuttle
    Build thread
    Rich, sorry if I misunderstood your intentions. Sometimes things that would be obvious in a person to person discussion are not knowable over the web.
    Janesville, WI
    How about this for a driveshaft.
    Quote Originally Posted by Packer fan View Post
    That looks like GoDadGo's drive shaft!
    Janesville, WI
    That is the result of a t56 magnum transmission ( a little longer than tko600) and a IRS.
    Bakersfield, CA
    Wow!!!
    Build thread
    good that it fits an IRS, not much room for axle travel.
    Janesville, WI
    Thank god for removable slip joints or I would have to pull the motor to change a clutch.
    https://www.markwilliams.com/holland...s-rr_yokes.gifEC85AEEF-9174-4A9E-B274-05266F0BA3DF.gif
    Senior Member Fixit's Avatar
    Minneapolis 'Burbs
    Driveshaft Angles & Phasing
    One of my Chevelle Club buddies posted this an eon ago... but it is useful info - the angles in the demonstration are exaggerated, but reinforces the need for accuracy...
    Driveshaft angles & phasing
    John D. - Minneapolis 'Burbs
    So. Bay (So. Calif.)
    And don't forget about the turbo encabulator.
    https://www.youtube.com/watch?v=Ac7G7xOG2Ag
  12. Likes cgundermann liked this post
  13. #52
    Sounds like a typical day at work for me. Only a room full of engineers could spend an eight hour day developing and documenting a procedure for the extraction and installation of a device used to produce electromagnetic radiation in the visible spectrum produced by energizing a tungsten element encased within a vacuum.
  14. #53
    Senior Member frankb's Avatar
    Feb 2014
    Marana, AZ
    I think we have drifted away from the original subject...
  15. #54
    Senior Member DavidW's Avatar
    Stevensville, MD
    You have now entered the twilight zone.
  16. #55
    Senior Member chrisarella's Avatar
    Clearwater, FL
    Anyone know for certain if the Metco Safety loop fits an IRS with a T56?
    https://www.metcomotorsports.com/pro...p?prod=MDL2500
    Mark IV Roadster #7679
    Coyote 5.0, T56, Hydraulic Clutch, IRS, Torsen Diff, Wilwoods, Hydraboost, ABS Power Brakes, Power Steering, & tons more extras.
  17. #56
    How many engineers DID it take to screw in the light bulb?
  18. #57
    None. They decided to put out a request for proposal for a maintenance contract and are now paying about $120 for the contractor to do it for them.
  19. #58
    Quote Originally Posted by chrisarella View Post
    Chris,
    I suspect this would work exactly the same for the IRS cars, but give them a call. They were very responsive when I contacted them.
  20. Thanks chrisarella thanked for this post
  21. #59
    Fairfax Station VA
    The picture I included with Post #2 is with the T-bird IRS and T5; that should give you a pretty good idea of whether the T56 would fit. Note that I shimmed the differential up 1/4" to get the pinion angle where I wanted it; that in turn forced me to use 3/4" spacers under the loop.
    MK IV Roadster #8631
  22. #60
    #9160 BB767's Avatar
    Chehalis, WA
    Looked on Fortes web site and could not find the "loop". Anyone have a direct link to it?
  23. #61
    Clearwater, FL
    It isn't on the site. Just call him.
  24. #62
    Lake Mills, WI
    Metco make one just for FFR MKIV
    Guys,
    Here is the link make for our cars:
    https://www.metcomotorsports.com/sea...=&stype=&scat=
    $129
    Well worth the insurance-just like the quick time explosion proof bell housing.
    Do it
    Martin
  25. #63
    Clearwater, FL
    Quote Originally Posted by magicmarto View Post
    Guys,
    $129
    Do it
    Martin
    Thanks Martin. Are these in stock? And will it work with the extra short driveshaft in a T56-Magnum/IRS setup?
    BTW, just an observation... you should add a link for Factory Five to your Vehicle navigation.
  26. #64
    Senior Member CFranks's Avatar
    Mar 2018
    Berwyn, PA
    Guys,
    $129
    Do it
    Martin
    Just ordered mine. I'm pretty sure this is going to be the strongest sales month in the history of Metco Motorsports thanks to this thread!
  27. Likes nucjd19 liked this post
  28. #65
    Senior Member RickP's Avatar
    Boyertown, PA
    Guys,
    $129
    Do it
    Martin
    yup, got mine too this week.
    RickP
  29. #66
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I got mine a few weeks ago. When I reached out to them, they had just fabbed them but they had not yet been powder coated. That was perfect for me since I ordered my chassis bare, so I got a bare driveshaft safety loop and I'm going to have it PC'ed along with the chassis so they match.
  30. #67
    Member Rook's Avatar
    Sep 2020
    Cary, NC
    I'm late to this thread, but wanted to post an answer here for anyone else who needs the info:
    I talked to Metco today and they said their test car actually used a T56 Magnum and IRS, so the answer is a definite yes!
  31. #68
    Clearwater, FL
    Quote Originally Posted by Rook View Post
    Ugh, already got one from Mike Forte but good that the info is here for others in the future.
  32. #69
    Member timmil's Avatar
    Chicago, Il
    Hey everyone,
    Totally on board and agree with the need but I am curious how hard and how much time would it take to install on a completed car? If anyone has any tips or insights please share.
    Tim
    FFR#5539 306FI, T5, 8.8 Rear, Hot Hues Jazzy Blue, Ford TS Stripes, Stock brakes, North Race Cars Axle 5-lug conversion
  33. #70
    Maumee, OH
    If you're talking the Metco on a Mk4, my son and I did it in 40 minutes from the time we jacked the car up to setting it back on the ground. If you're talking the Forte unit, it takes quite a while longer, as you have to remove the driveshaft slide it inside the hoop and then reinstall the driveshaft. Those threaded nutserts are quite tricky to get aligned on round tubing.
    Scott
    Built FFR9457. 351 Windsor, TKO600, 3.73. Fitech EFI. Russ Thompson throttle pedal, turn signal, and trunk pan. Carbon Fiber dash with Speedhut Revolution gauges. Paint by Jeff Kleiner.
  34. Likes bldr.rob liked this post
  35. #71
    Chicago, Il
    Thanks Scott. I am going to be installing a Metco on an MK 3.1. Don't know if that changes anything.
    Tim
  36. #72
    Fairfax Station VA
    That 40-minute number is best case. If you're like me, you'll need some spacers under the loop, which meant longer bolts. Between fabricating the spacers & a trip to the hardware store in Northern VA traffic, the job turned into half a day.
    I also had to re-route my brake cables so that they didn't rub the loop. I didn't find that out 'til later in the build.
    Still worth doing though.
    IMG_3369 by jhsitton, on Flickr
    IMG_3530 by jhsitton, on Flickr
  37. #73
    Nov 2018
    Centennial, CO
    ...or spend only 20 bucks on a speedmaster universal loop and spend three days fabricating your own mounting
    Bradley
  38. #74
    Jan 2020
    SEPA
    Anyone experiencing an issue of the loop vibrating on big bumps and hitting a driveshaft?
    Build thread
    FFR mk4 roadster complete kit, 347 cu in carbed BluePrint engine, TKO600, IRS, power steering, ordered Jan2020, delivered 3/25/20, titled 8/23/20, finished 07/17/2021, graduated 10/06/2021
  39. #75
    Fairfax Station VA
    That would have to be some bump! As you can see from the pictures I posted, there's at least a full inch of clearance between the hoop & the drive shaft.
  40. #76
    Jan 2020
    SEPA
    In your case, with spacers - yes. I don’t have spacers and I feel like the loop vibrates on bumps and sometimes touches the driveshaft. I’m gonna lift the car later this week and will take a closer look
    Build thread
  41. #77
    Seasoned Citizen NAZ's Avatar
    Quote Originally Posted by alexmak View Post
    If your safety loop is vibrating that much I'd be concerned that it would have little chance of containing a driveshaft failure. The energy released when a u-joint lets go is impressive.
  42. #78
    Jan 2020
    SEPA
    OK, so here’s what my issue with driveshaft loop was:
    1. It’s attached to the transmission mount in the front, but the back of the loop part is essentially hanging in the air (on the photo - right side)
    Which means that the rear part of the loop mount plate was vibrating
    2. Since I haven’t used any spacers for the loop itself, it was pretty close to the driveshaft from the top
    So on some large bumps it would vibrate in way that it the loop was hitting the driveshaft.
    3. Once I installed the “spacers”, the problem seems to go away
    (Unless I missed some important part of the driveshaft loop mount instructions, of course)
    Build thread
  43. #79
    That amount of shim seems just a bit excessive. I would think you could do with half that much. Also, if your parking brake cables are anywhere close, check to make sure they are not rubbing on the edge of the loop.
    I can't remember if I used a 3/8 or 1/2 shim, but it was a fine line between clearing the drive shaft (3 link) and not having the parking brake cables rubbing on it. I ended up "rounding" the edge of the safety loop so that the cables, although just barely touching, will not chafe.
  44. #80
    Jan 2020
    SEPA
    Thanks! I started with half, but i was still able to pull the plate for loop to the driveshaft, so added more. the loop is shifted to the side to reduce the amount of touching the loop as much possible.
    I’m actually reconsidering the need for this loop, since it looks like I’m going to be doing mostly street driving with a sane amount of horsepower.
    Build thread
