Cut the leeding edge? The cut will not need to be as precise and some deformity in the front is probably better than the rear
If you did this you may be able to cut it with a sharp blade
I am also looking at this option, but it would require a very steady hand to make a straight 4ft. cut!
Yes, I'm still thinking about how to rig the blade up really tight. I want to only cut one half so the there is no alignment issues. By cutting only the trailing edge, the foil snaps around the bar like a clamp and keeps its shape well.
The foil is a hard ABS plastic and would not cut with a sharp blade. I thought about cutting the leading edge, and I may still do that if I can't cut the trailing edge well enough. Luckily I have another piece if I screw up!
MK3.1 Roadster completed 2011
