Hello all! I'm getting ready to tackle on the engine install and just wanted to see if any of you with experience has any tips or tricks or even advice regarding this coyote install that will help me. so far the the only thing I've done in the engine bay is installed the breeze front battery tray so I know I have a long way to go but I have most parts already for the engine trans install at least I believe I do.
Parts ive collected so far:
-gen 2 crate coyote from summit racing
-ford control pack
-krc power steering setup
-moroso oil pan
-moroso overflow tank
-mustang gt 2016 starter
-ford alternator kit
-intake parts "via factory five coyote install instructions"
-Russ Thompson gas pedal for the Coyote Controls Pack
-factory five full headers
-factory five coyote install kit
-factory five engery engine mounts
-factory five efi fuel setup with pressure regulator
-tko600 with all the parts needed to install that Forte parts connection put together for me.
Maybe you can help me and direct me to the correct coolant hoses I would need to purchase? I'm using the ffr rad.
any tips on wiring? I have the factory five Ron Francis harness.
Thanks to you all in advice and hope you can help me get through this install as this will be my first time installing an engine ever.
