Thanks Thanks:  2
Likes Likes:  4
Results 1 to 18 of 18
Thread: 3D printing is advancing
    Sacramento CA
    This may be old news but I can't wait to get the bench top model for the garage!
    https://industrialmachinerydigest.co...sample-part-2/
    What would you make???
    ej95Cobra's Avatar
    Central Virginia
    My son 3-D printed a number of items for our build. These include:
    - brackets to attach the Canon coolant overflow tank and the CNC brake fluid reservoirs to the upper braces along the hood opening
    - a bracket attaching the MSD box to the cross brace above the radiator
    - 2 piece Grommet for passing brake fluid hoses, ss brake lines & some wires into the engine compartment
    - bracket in the engine compartment with remote battery terminals to attach battery tender (battery is in the trunk)
    - a number of 2 piece clamps securing the ss fuel lines and the ss brake lines
    These made for clean attachments and look nice.
    Mk4 Complete kit #8469: Levy Racing Stage 5 with Inglese stack. TKO 600, 3 link rear suspension. FAST Sportsman with dyno-tune. APE hardtop. Father & Son project, delivered Nov 2014, completed June 2017.
    Rotonda West Florida
    Have good ventilation see this article just published
    https://www.engadget.com/2016/02/01/...an-be-harmful/
    Mar 2013
    Fort Collins, Colorado
    Not car related, but the Army can 3D print a concrete barracks building in 2 days vs a stick build in 7 days. Not pretty, but functional and cheap.
    https://www.dezeen.com/2018/09/05/us...te-technology/
    Senior Member Clover's Avatar
    Colorado
    I saw a company recently did a concept set of wheels that were 3D printed from titanium which was super cool. The company was explaining that they normally start off with a ~100lbs. block of aluminum and machine away 80%. When 3D printing, there is very little waste which makes a material like titanium doable, where as cutting wheels from a giant block of it is not cost effective. Now, it is not your standard 3D printer they are using but this could be more common place one day not too far out.
    Gen III Type 65 Coupe Delivered 6/26/2018
  6. Likes cgundermann liked this post
    Nov 2018
    Chandler, AZ
    I’m looking forward to using my 3-D printer to make Cobra items. Even little assembly jigs are easier with it.
    Quote Originally Posted by ej95Cobra View Post
    This sounds awesome. The 3D printing really intrigues me. Could you post some pics of these parts please? What material are they printed in? Is in plastic, any concern with engine compartment heat?
    Senior Member Mike N's Avatar
    Mooresville NC
    Quote Originally Posted by Clover View Post
    https://www.youtube.com/watch?v=9F2FMIzXw5M
    Mike............
  10. Likes Straversi liked this post
  11. #9
    Chino Valley, Arizona
    Quote Originally Posted by Mike N View Post
    That is truly incredible and fascinating! Like Scott, I have been intrigued and kicking around 3D printing...
  12. #10
    May 2016
    There may be a day, in the very near future, that we can share the files that allow you to print out these special parts specifically for the FFR cars. Just think, an open source file sharing site for FFR parts, just click and print. Also there is room for sponsors to then sell their very own version of these parts at great prices and help to the community.
    Brandon
  13. #11
    Some guy's I know 3d printed a complete car. This is me in it.
    The second one is the 3d printed (in case you couldn't figure it out)
    The first car belongs to David Riha.
  14. Likes Derald Rice liked this post
  15. #12
    Stillwater, NY
    Brandon
    You can do that now. And if you don't have a printer to can send the file to a printer service.
    https://www.thingiverse.com/
    People will laugh, but in the future, everything will be printed. Auto parts stores will print your part instead of stocking them. You will have a printer in your home to make everything from clothes to shoes to appliance repair parts. Even complex parts with electrical circuit boards will be possible. Maybe not in our lifetime, but it's just a matter of time. Most of it is possible now, just not large scale or fast enough.
  16. #13
    Bakersfield, CA
    It’ll be just like the Jetsons!
    Build thread
  17. #14
    Apr 2018
    Colgate, WI
    I was in a ship building facility in August that mounted robotic welders unto the gantry crane systems. Looked like something out of a SyFy movie. In addition to massive seam welding they are now welding small features directly. Things like brackets and stops. They can add up to 8lbs of material per hour per welding head. They are also planning to add a combined 3D welding / CNC work cell. CNC cleans up the surface and drills holes directly after the part is weld/printed.
    Mk4, IRS, (Forte: 427 with EFI, T-56 MAG, hydraulic clutch, mechanical linkage, reverse lockout control module) (Breeze: Front and Rear Double adjustable QA1's, Cockpit cubby, LED Lights, Fan Shroud, Fan Lower Support, Oil Cooler Coil, power steering hose kit) (Russ: Drop Trunk, Turn Signal)
  18. Thanks Derald Rice thanked for this post
  19. #15
    Senior Member FLPBFoot's Avatar
    Cape Coral, FL
    The Engineering department at Bradley Univ, my alma mater, is in a NASA competition looking at colonizing Mars. Their project is to look at sending materials and 3D printers to Mars and 3D printing everything from living quarters to transportation equipment. Much easier to send it in bags and make it out there. Amazing stuff.
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
    1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
  20. Thanks Derald Rice thanked for this post
  21. #16
    Sacramento CA
    ORNL 3D Prints Working Shelby Cobra Replica (2015)
    https://3dprint.com/36433/3d-printed-shelby-cobra/
    I ran across this but did not want to start a new thread. then ran across this thread while searching for 3D printer threads.
  22. #17
    Mar 2021
    SE WI Kettle Moraine
    Two caveats:
    Not all manufacturing methods yield the same results. A sand casting is fast and cheap, a forging delivers better structure, with smaller cross section. Differing physical characteristics of the same material.
    I see the HRE/GE printed titanium was a styling exercise but durability and yield strength? Three years later?
    It is hard to believe that electron beam micro-melted material has the physical properties of an ingot forged to shape with tons of pressure.
    I sat in on a contract design company's review of a small part manufacturing presentation to sell a machine for printing small batches of parts.
    It all looked good until I asked if the material was solvent, antifreeze, petroleum or heat resistant? No it was not.
    jim
  23. #18
    Sep 2015
    Hamersville, Ohio
    It’s cool for non structural parts. My car will have an absolute minimum of plastic parts. Imo, most collectible cars are from an era before the advent of plastics everywhere. I agree with Mr Jones that printing of metal parts is still far from the structural integrity of billet or forged materials.
  24. Likes J R Jones liked this post
