Results 1 to 5 of 5
Thread: swapped tranny= No speedo gear, CEL, no Cruise, Fans on blast!...............ARrggggh
    Mar 2017
    West Phoenix
    So I realized really late what I had missed when replacing my trans that had a blown Pinion. Now I have this issue. I have to erase the VSS code and cycle the key every time till the next drive cycle It happens again. My options.........
    -Open it up again and see if the VSS driven gear is actually there to mate with the plastic sender gear
    -convert speedo to GPS but I might still have a CEL and Fan issue.
    -Dakota Digital speedo Interface............ THis seems like the smartest solution for $80.
    Anyone have experience with the DD interface? I have all the ABS sensors attatched and working.
    Mac1
    when my 04 5mt failed I found a good deal on a 2012 5mt the doesn't that the VSS hole in the transmission bored out.
    On my front left hub I cut 5 teeth in to the CV joint bearing cup. Then used a $20 industrial prox sensor wired to the VSS signal. Dash speedometer and ECU work perfect.
    Let me know if you want more information.
    Mar 2017
    West Phoenix
    I got this fancy hub block off that has ABS ring attatced to it. But if all I need is a axle stub to chop up
    So what year is your ECU and cluster? Mine is '06
    Maybe some help choosing the sensor would be much appreciated
    Hey Mac1
    Here is the sensor I used:
    Part # EZ-M12-MPNNO-NMW
    https://store.ezautomation.net/produ...-npnno-nmw.htm
    Here is how it is wired. Top is new prox, bottom is the original gear driven part.
    My ecu and cluster are out of 04FXT. Anything 02-07 impreza or forester should be the same.
  5. Thanks walt555 thanked for this post
    Likes walt555 liked this post
    Mar 2017
    West Phoenix
    I ended up fixing my speedo with this device.
    Only starts to work at 20mph but cured my issue completely.
