Results 1 to 6 of 6
Thread: Steering wheel hub bolt pattern
    Top Notch Builder P100DHG's Avatar
    Pasadena, CA
    I cancelled the steering wheel that came with my kit. I am looking to buy one I prefer more, what is the bolt pattern here called? What should I be looking for?
    http://www.factoryfiveparts.com/1252...ng-wheel-boss/
    Norton, MA USA earth
    Pretty sure its FFR specific. It is not a consistent bolt circle either.You may be able to drill the hub to match whatever you buy though.
    You might send a note to Russ Thompson, as he does custom machining on the steering wheel boss for his turn signal setup. He may be able to provide the specs and offer recommendations on what would fit.
    Pasadena, CA
    Is the steering rack universal that I can just use a boss that comes with steering wheel like this
    https://www.ebay.com/itm/65-1969-For...08b6%7Ciid%3A1
    Another example
    https://www.ebay.com/itm/1978-to-199...08b6%7Ciid%3A1
    If you want a different wheel then you may want to install a Quick Disconnect like one of the types shown below since they have multiple patterns:
    https://www.jegs.com/p/JEGS/JEGS-Qui...58026/10002/-1
    Also, check out this earlier forum thread if you want to see other solutions:
    https://thefactoryfiveforum.com/show...+quick+release
    You just need to have the wheel spline Tig Welded to the 3/4" shaft.
  6. Thanks P100DHG thanked for this post
    Pasadena, CA
    Just to give resolution to this thread, I’m sending out my boss to Russ Thompson he has the Momo bolt pattern.
