Likes Likes:  2
Results 1 to 23 of 23
Thread: Lower coolant hose bracket
    Janesville, WI
    Has anyone put a bracket on the lower radiator hose to help support it at the cross bars?
    I am trying to find something that might work. Or is the consensus that it doesn’t need one.
    Chino Valley, Arizona
    I felt it was needed for my configuration and this is what I did:
    Grand Rapids, MI
    Depends on your hose / pipe. I used the ones from Breeze and I put a stick on rubber isolator on the round tube under it to prevent rubbing and it’s been fine. With solid pipes you may not want to fix them as that would restrict a lot of movement and could cause issues. The FFR stainless hose flexes and probably could be clamped. The answer depends on your routing and what your using.
    So. Bay (So. Calif.)
    Breeze has a bracket on their site. https://www.breezeautomotive.com/sho...k3-1-roadster/ I rounded the bracket tabs to conform to the round X-cross bar.
    All of them I build get a 20 cent conduit clamp from the hardware store.
  6. Likes TexasAviator liked this post
    Woodstock ,Illinois
    There you go Jeff!!! A 20 cent upgrade! Wait till da Bat hears this!
    Raleigh NC, OIB NC
    Have the Breeze stainless steel COYOTE lower hard pipe with the $0.20 solution. Recommend the Breeze pipe over the FFR pipe.
    Kevin
    MKIV #8234
  9. #8
    Janesville, WI
    I used Breeze for the upper. They didn’t have a hose for the bottom with a Coyote. They did recommend Boig Motorsports for the lower. It is a contoured stainless tube with hose on either end.
  10. #9
    May 2016
    I used a chrome coil cover bracket I got from my local auto parts store. Its made for the ignition coil but I repurposed it after I retrofited a hotter coil from a fox body mustang EFI car.
    Here is what it looks like.
    https://www.4wd.com/p/mr-gasket-comp...AaAreJEALw_wcB
  11. #10
    Bakersfield, CA
    Chris[/QUOTE]
    I’m probably gonna feel dumb when you tell me, but what are the two red round things Chris?
    Kurt
    Build thread
  12. #11
    “Re-purposing” is such a fun & satisfying part about building a car from the ground up. I often just walk down the aisles of Home Depot or Lowe’s looking at various non related things to see how I can re-use them. I’ve come up with the darnest fixs...
  13. Likes TexasAviator liked this post
  14. #12
    Leesburg, Va
    Chris[/
    Kurt
    Just a guess, a pair of horns!
    Doug
    FFR 7995
  15. #13
    Bakersfield, CA
    One of my thoughts... but still ?
    Build thread
  16. #14
    Kurt[/QUOTE]
    Hella horns...I had a basic kit, so I had to come up with horns and that’s were I decided to mount them...
  17. #15
    Quote Originally Posted by Bobby Doug View Post
    Winner, winner - chicken dinner...
  18. #16
    May 2016
    i do the same thing Chris. Car is getting darn near done and I am driving it but I still look for things to add to the car all the time.
  19. #17
    It’s a sickness...lol...
  20. #18
    Bakersfield, CA
    Thanks Chris
    (And Bobby lol)
    Build thread
  21. #19
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Lots of Breeze parts on my car - including their lower pipe with a bracket and rubber isolator.....
    Later,
    Mk3.1 #7074
  22. #20
    Now that’s a nice piece! The rubber idolater would be worth it...
  23. #21
    Quote Originally Posted by steno View Post
    Miller will have a ten cent retrofit clamp that he has a modest opinion/preference for...lol...
    We haven’t had dueling banjos from our Forum superheroes for a while now...
  24. #22
    That's just because you aren't privy to our text messages
    True Dat...Lol...
