Concerning the electrical connections...I used the same crimp on butt connectors that Edward B mentioned. After ordering them, I talked with a tech guy from Aeromotive. He suggested using these connectors sold on Amazon. Here. He said he personally uses them for fuel pumps. I can't verify they work or will hold up, but it's another option for anyone to consider. It's also a lot cheaper then the Delcity option; I had to order a minimum of 10 and the shipping was expensive. It cost me about $32 for the 10 connectors. The connectors from Amazon are $14 and you get 50 connectors of different sizes.
Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
Serial #9158
