Tremec TKO reverse switch
Seems that I've been bit by the "assume" mantra again... Don't assume, 'cause it'll make an *** out of U and ME.
When I was doing the rear wiring on #9365, I prepped for reverse/backup lights. I assumed the switch on the Tremec was an N.O. (normally open) switch, that closed when the gearbox went into reverse. It appears that this is not the case. It goes "open" on shifting to reverse.
Question is:
Does Tremec offer a N.O. reverse switch?
John D. - Minneapolis 'Burbs
