Results 1 to 10 of 10
Thread: rear coupe hatch hinges?
    Jul 2014
    Strathroy, Ontario Canada
    either I am blind or its not in the manual but I did not see how to attach the rear coupe rear hatch to the hinges. It looks like it uses 1/4-20 bolts but the panel is not drilled out I have pilot holes drilled and it seems like there is aluminum in there. I am guessing it is drilled out and tapped for the 1/4-20 bolts or maybe deep nutserts?
    please advise what you coupe guys did.
    thanks
    Senior member
    Carlsbad,Ca
    Page 443 in the 818S manual ,rev 1Q shows pic
    Jul 2014
    Not sure what rev factory five sent me but it's not on that page. How is it attached to the hatch?
    Jul 2014
    They sent me rev 1T I will try and get the next rev.
    Senior Member AZPete's Avatar
    You're correct that there is aluminum inside the hatch frame where the hinges are to be mounted. Mark where you want the holes, drill and tap (I tapped 1/4 x 20). There is some wiggle room in the hinge mount holes so you can adjust before tightening the 1/4" bolts. Have patience in getting the hatch tp fit , but it will eventually.
    Next, the hatch latch is explained in detail in the manual, but the hatch struts not at all. There was a good thread about this eons ago, so I'll try to find it and post later.
    Merry Christmas.
    now it's later so here's the strut thread;
    https://thefactoryfiveforum.com/show...t-instructions
    Jul 2014
    perfect thanks so much. it seemed like a drill and tap thing. cheers
    Aug 2017
    I am so glad others have blazed this trail. I wanted a plan before mangling the fiberglass on the blind hope there was something there to mount them to. I'm using a 7/32" bit for the 1/4"x20 tap.
  8. Likes AZPete liked this post
  9. #8
    Apr 2014
    my approach was drill and rivnut
  10. #9
    Norton, MA USA earth
    Use a #5 drill or 13/64
  11. #10
    Sep 2015
    Hamersville, Ohio
    #7 drill for 1/4-20 tap
