Results 1 to 11 of 11
Thread: Factory Mustang Bullitt Rims on FFR Roadster
Hybrid View
    Senior Member Yama-Bro's Avatar
    Jul 2012
    Kearney Nebraska
    I may have a chance get some Ford Mustang Bullitt rims. Do these rims work on our roadsters? I've seen similar rims, but I'm not sure if they are Bullitt's or Anthrcites? Whichever ones I've seen, I really like the way they look on our roadsters. Do the factory Bullitts have the proper back spacing and all that good stuff? Anything to watch out for?
    Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
    Serial #9158
    Maricopa AZ
    The SN95 bullet wheels will fit but they are only 8" wide which will have huge limits to tire size.
    Yo-Bro-Yama,
    Check out OEWheelsLLC.
    https://www.oewheelsllc.com/Wheel-Si...tang/year/2002
    I've bought wheels for my old C-4, son's Camaro and my MK-4.
    I think Jeff Kleiner is running a set of them on his car too.
    Yes, I am and have built cars with them also...including this one with a set of their Bullitts
    17X9 and 17X10.5 with SN95 specs.
    Jul 2012
    Kearney Nebraska
    Thanks for the feedback guys. It sounds like if they are OEM Ford Bullitt rims, I should probably stay away from them due to tire options. A guy I work with has them on his 'Stang. The rear wheels seem to have a deep offset... it makes me think that maybe they aren't stock. I'll have to do some measuring. Thanks!
    Serial #9158
    Late Model Restoration Has Some Other Options That You May Want To Look At Too:
    https://lmr.com/products/94-04-Mustang-Wheels
    Also, though not produced by OEWheels any longer, LMR still produces the 10th Anniversary wheel which is what I've got.
    https://youtu.be/NhRHwAbtrt0
    You've Got Some Great Options Out There & The Bullitt's Definitely Look Period Correct!
  8. Thanks Yama-Bro thanked for this post
    May 2016
    I used lmr.com 10.5 and 9 inch wheels with sn95 rear axle and spindles. I am running 315 and 275 tires.
    Click for a larger pic.
  10. #9
    Jul 2012
    Kearney Nebraska
    Cool plates BTW.
    The ones I have a chance to purchase are used, so they are what they are...which I believe them to be stock mustang Bullitt rims. So they are most likely to narrow. Thanks for the input guys!
    Serial #9158
  11. #10
    May 2016
    Agreed, the look you are going for isn't going to be met with stock wheels. Lmr.com wheels with 3 inch lip cost 400 for the set. I quit looking after I found these. Got nt555 tires and wheels for about 1200. Done deal for me.
  12. #11
    Jul 2012
    Kearney Nebraska
    Just a follow up on this post I started. I ended up buying the used rims. They weren't stock mustang rims after all. They are actually aftermarket rims. They aren't in perfect shape, but I got them cheap enough, that it doesn't matter. Now I'm up to three sets of rims for my roadster. I better cool it with the rim buying...although I don't have a set of 18's yet....hmmm.
    Serial #9158
