0
Permanently attaching aluminum panels...when?
Hi Guys,
I just finished installing my fuel lines. My brake lines are in, but I may go back and make a change to the one that runs down the front of the foot box. I think my next step is to start on the wiring harness. So far the only aluminum panels I have permanently attached to the frame are the F panels and the front of the footbox. It has been very handy to be able to remove the floor panels and the trunk panels while doing the brakes and the fuel lines. However, now that I am about to start the wiring, I was wondering if I should start making some of the panels permanent parts of the car? For instance, should the foot boxes and the firewall be attached to the frame before the wiring (except the outer and top of the driver side)? I can see leaving the trunk loose for now, but how about the cockpit floor?
Serial #9158
