Thanks Thanks:  3
Likes Likes:  3
Results 1 to 30 of 30
Thread: Newbie’s crazy questions
    Jan 2019
    Mandeville, LA
    My first build and I’m a Jeep/truck guy and have only really dealt with SBC motors. Instead of making multiple threads, I’m hoping to ask all my questions on this one.
    Thanks for helping.
    Here is the first. Panhard bar on the drivers side. There are two spacers. Does one go on each side of the bar end or both in the back. This changes the horizontal angle of the bar. Does it matter?
    Maricopa AZ
    1 on each side. Bar needs to be as level to the diff as possible
    Jan 2019
    Mandeville, LA
    Thanks. That’s what I figured. The pic in manual shows them both in the back. Instructions say something like “mount it with the spacers provided”. It is clearly written for the passenger side,
    Jan 2019
    Mandeville, LA
    After installing all of the 3-link rear end components, I was left with 2 1" allen head screws and bolts. About 3/8 diameter. Looked through the manual, but don't see where they go. Any ideas?
    Maricopa AZ
    Sounds like the bolt that connects the forward leg of the banana bracket to the diff housing.
  6. Thanks Dagwoods thanked for this post
    Kirkland, WA
    I believe I had hardware left over after installation of the 3-link, too. Complete kit circa 2016.
    Mk4 #8861 Complete kit. Delivered: 27 Apr 2016, currently a roller.
    Gen-2 Coyote, clutch, TKO600, midshift, and solid axle from Forte. Many pieces from Breeze and Replicarparts.
    Jan 2019
    Mandeville, LA
    Thanks. I’ll check tonight. My rear came with all of that bolted on already, so that sounds very plausible
    Jan 2019
    Mandeville, LA
    Trying to decide on cup holder placement so I can the trans tunnel wrapped. Don’t want it to get in the way of the shifter. I’m limited going forward by the center dash support. If I go all the way toward that and to the left will it interfere?
    On another note, anyone able to post pics to posts from their phone? I can’t figure it out.
  10. #9
    Jun 2015
    Fairfax Station VA
    Clearly what I did won't work with the center dash support, but there are several factors at play in addition to the diagonal bracing at the top of the tunnel.
    I found that the trick is to get the right depth cup holders. On my MKIV, I ordered three pair before I found these (https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1). They were the only cup holders I could find that were large enough for my phone case to fit in AND shallow enough to fit at the front of my transmission tunnel. I located them 6” from the forward cockpit wall and 3” to either side of the center line of the transmission tunnel cover. More information is in Post #352 of my build log (https://www.ffcars.com/forums/17-fac...ter-build.html).
    IMG_4002 by jhsitton, on Flickr
    IMG_4752 by jhsitton, on Flickr
    MK IV Roadster #8631
  11. #10
    Jan 2019
    Mandeville, LA
    Thanks. The 2nd picture is really helpful. Any way you can throw a tape measure in the same picture? Measuring from the front going back.
  12. #11
    Jun 2015
    Fairfax Station VA
    Sure. The shifter trim ring is 16 5/8" back from the front of the transmission wall. Note that this is for a T5. The gear shifter is in neutral, if that helps.
    IMG_5403 by jhsitton, on Flickr
  13. #12
    Jan 2019
    Mandeville, LA
    Rivnuts are driving me crazy! I get about 1 good one set for every 3 that end up turning in the hole. I've adjusted the tool down to the point where it doesn't squeeze it enough to hold. Anyone ever try tack welding a steel rivnut in the frame?
  14. #13
    O'Fallon, MO
    Quote Originally Posted by hjoensy View Post
    Use a drop of red loctite, they won't turn.
  15. Thanks Mark Eaton thanked for this post
    Likes Ducky2009 liked this post
  16. #14
    Heath,
    I try to not rock the rivet-nut during the final squeeze of the handle too.
    Also, I've got a couple of odd ball drill bits that allow me make the tightest hole possible.
    Yes they are a pain in the neck, but once you figure them out you'll be shocked at how often you use them.
    Jax Beach, FL
    As GoDad said, don't drill too big a hole. Sometimes I would do a squeeze, then get a couple more turns on the knob and hit it again. I like the loctite idea.
  18. #16
    Jan 2019
    Mandeville, LA
    I traded out the aluminum rivnuts for steel. Much much better. I love the loctite idea.
  19. #17
    Jan 2019
    Mandeville, LA
    I have zero experience with front end alignments and will bring to a shop once running.
    For now, I need it to roll out my garage to install the engine. Both front tires are kicked in at the front of the tire. The car looks severely pigeon toed. I read the manual.....but it says bring it to a shop.
    Any advice on how to get semi-correct would be appreciated.
  20. #18
    Heath,
    I can probably help you get in the ballpark one night after work or definitely next weekend.
    Jan 2019
    Mandeville, LA
    Sounds good. Let me know.
  22. #20
    BadAsp427's Avatar
    Greeneville, TN
    Take a look at this post, it could be a big help for you to get started... CLICK HERE
  23. Thanks Mark Eaton thanked for this post
  24. #21
    Jan 2019
    Mandeville, LA
    Awesome thread. I looked, but couldn’t find anything this detailed. Thanks.
  25. #22
    Jan 2019
    Mandeville, LA
    Will installing the radiator before the engine cause engine installation clearance issues? I’m running out of things to do before the engine shows up.
  26. #23
    BadAsp427's Avatar
    Greeneville, TN
    IMO, wait until the last chance to install the radiator. You will have many things going on in and around the front of the car that you will wish it was not in your way. But, if you do, I would be sure to protect it with a sheet of cardboard or something.
  27. #24
    Heart of Dixie, Alabama
    Hang the radiator, drill and bolt everything in place, pull it and set it aside. You will be glad all the fitting is done.
  28. #25
    Jun 2015
    Fairfax Station VA
    Make sure the right side mount clears the weld on the radiator. Depending on the model, you may have to grind off a bit of the outside corner.
    IMG_2750 by jhsitton, on Flickr
  29. #26
    Jax Beach, FL
    Hang the radiator, drill and bolt everything in place, pull it and set it aside. You will be glad all the fitting it done.
    .....and ALWAYS keep cardboard over it while it is sitting in the garage.
  30. #27
    I'd suggest installing the radiator after your driveline goes in to avoid damaging it.
    If you need help installing the engine, please know we're willing to lend a hand.
    If you want to drag it to The-Dell we can do that too since I've got a trailer.
    Installation With No Body:
    https://youtu.be/3f1Q4aS5SG4
    Removal With Body:
    https://youtu.be/Vhbftk4AP4k
    Installation With Body:
    https://youtu.be/-nVDzIjSjh8
    Helping Each Other Is What Factory Five Folks Do!
  31. #28
    May 2016
    I want to build a cobra. At least I think I do. Can anyone make a short comparison of the factory five and backdraft cobras. Just stick to the important stuff. Chassis, fiberglass body, interior. Whatever you considered when you decided to build your factory five.
    Thanks, Dan Raabe
  32. #29
    Quote Originally Posted by Dan Raabe View Post
    Thanks, Dan Raabe
    The biggest difference between Factory Five & Backdraft is everything!
    Backdraft's Chassis is basically BMW suspension parts on a rectangular tube chassis and the body sits on top like a dune buggy.
    Shown below is a link to let you see the B/D chassis:
    https://backdraftracing.com/14-rt3-tabs/44-rt3-chassis
    The Factory Five Racing Chassis is much like the original being that it is a 4" round tube design for a more period correct look.
    Shown below is a link to let you see the F/5 chassis:
    https://www.factoryfive.com/gallerie...dster-chassis/
    Backdraft is built outside of the country, uses foreign labor and builds "A Nice Looking Car" but it is far from being period correct.
    Purchase a driveline and install it or have it installed and you are done.
    Factory Five builds their cars in the U.S.A. by American Craftsmen and Craftswomen and the Roadster body is very period correct in shape and style.
    Build a Factory Five and your car is truly your car and it will reflect your skills and ability, but more importantly it will include your soul.
    Factory Five MK4 Overview By Dave Smith, President & CEO For Factory Five Racing:
    https://youtu.be/6ckgfkPU8Ss
    How Factory Five Makes Their Cars:
    https://youtu.be/wVT6QHyBxDA
    https://youtu.be/GvkJ95X7Fio
    How Backdraft Builds Their Cars:
    https://youtu.be/4Ts87Ta3qik
    Where Factory Five Gets It's Inspiration From; Which Is Racing:
    Real Cobra
    https://youtu.be/KpYxA9QTMxE
    Factory Five Roadster
    https://youtu.be/X9OSrHFECxc
    My Car Then & Now:
    https://youtu.be/_wnHDNgnNqs
    https://youtu.be/wOID7yvBRPU
    Again, The biggest difference between Factory Five & Backdraft is everything!
    Do You Want To Build Your Dream Or Simply Purchase It?
    The Choice Is Yours!
    Good Luck!
  33. Likes FLPBFoot liked this post
  34. #30
    Cape Coral, FL
    Here Here...well said.
