Results 1 to 13 of 13
Thread: Brake Bleeding
    Mar 2017
    Brake Bleeding
    Have my Willwood brakes installed and moved on to bleed them using the standard two person procedure. Could not get the fluid to move after multiple pumps, holds, open/ closes. The level in the resevoire did change. Any suggestions?
    Also I noticed there are 4 nipple valves per caliper....what's up with that? My past experience with brake bleed only had one nipple for each caliper.
    Heart of Dixie, Alabama
    Multiple bleeder locations, so the calipers can be used in different locations and still have a bleeder at the high point. Try topping off your reservoir and opening the top bleeder on the right rear caliper. Put a rag on the floor and be patient. Leave the cap off the reservoir.
    Raleigh NC, OIB NC
    Don't have Willwood calipers just the master cylinders. A couple of bleeding attempts were totally unsuccessful. Bought a hand pump-up pressure bleeder & 100% successful first try.
    Did you bleed the master cylinders before yo installed the lines?
    Kevin
    MKIV #8234
    Mar 2017
    I did not bleed the Master Cylinder. How do you accomplish this?
    Thanks for your help.
    May 2016
    I made this thread for us innovative types. LOL. Its pretty effective and uses inexpensive stuff to bleed the entire system including the master.
    https://thefactoryfiveforum.com/show...op+brake+bleed
    Dual MCs usually bleed better if you have two helpers available so you can open a front caliper + rear caliper at the same time - this way you're stroking both MCs instead of trying to stroke one + exercise the bias bar.
    Either that or pressure bleed.
    I made this up from hardware store stuff.
    Pressure Bleeder by craig stuard, on Flickr
    I happen to have a pressure regulator that goes to 5# so I use that. A friend used a fish tank air pump. I prefer pressure to vacuum because some bleeders leak at the thread when opened so, even though there is no more air in the line, you still see bubbles.
    Mark Dougherty's Avatar
    Hershey PA
    P/m sent
    I will happily walk you through the procedure we use.
    The traveling Builder
    717-773-5624
    Senior Member Duke's Avatar
    Taxachusetts
    I too fought this for many hours. Here's what worked for me after I didn't bench bleed:
    With the wilwood pedal box dual M/C's, I found that I had to do both front and rear at the same time. Otherwise I wouldn't get the full compression of the M/C's. Have someone press the brake down and hold. Bleed pass rear (open/close bleeder valve), then go to pass front and bleed (open/close bleeder valve). Once done, then have brake pressure released. Repeat multiple times then do driver side.
    Raleigh NC, OIB NC
    Same concept except you are working with two cylinders instead of a single dual unite like in the vid.
    Kevin
    MKIV #8234
    Mar 2017
    Thanks. Got your message. Will try to call today.
    Mar 2017
    Thanks. Can you please walk me through your process?
    Maumee, OH
    I struggled with this and finally bought the HF vacuum pump for $20 bucks. Half an hour later and it was done. Save yourself the headache. I pumped for almost an hour trying to get fluid to move. This did the trick, easy peasy.
    Scott
