I got my seats located on the temporarily installed floor pan. I have sat on a life jacket to crank the car, but never in the seats as they should be located. Besides the contortions needed to get in and out, my gas pedal is too close to the brake. I can see under hard braking, my foot overriding on the gas pedal. I have the drive by wire pedal with the FF pedal bolted on.
Rather than trying to bend offset into the FF arm, it looks like l might be able to put the arm on the inside of the Ford arm.
My front floor pan is still loose, so I should be able to work in there OK. It looks like I need the pedal as close to the inside foot box wall, as possible. Maybe just enough room for heat shield and carpet. I guess foot size/width has a lot to do with what will work. I am open for suggestions. Thanks,
