Results 1 to 16 of 16
Thread: Gas pedal location
    Gas pedal location
    I got my seats located on the temporarily installed floor pan. I have sat on a life jacket to crank the car, but never in the seats as they should be located. Besides the contortions needed to get in and out, my gas pedal is too close to the brake. I can see under hard braking, my foot overriding on the gas pedal. I have the drive by wire pedal with the FF pedal bolted on.
    Rather than trying to bend offset into the FF arm, it looks like l might be able to put the arm on the inside of the Ford arm.
    My front floor pan is still loose, so I should be able to work in there OK. It looks like I need the pedal as close to the inside foot box wall, as possible. Maybe just enough room for heat shield and carpet. I guess foot size/width has a lot to do with what will work. I am open for suggestions. Thanks,
    If you have the Wilwood clutch and brake pedals, move the pads to the left if you haven't already. You can see what I mean if you look at how the clutch pedal pad is attached in the picture below. That will give you some additional space between the brake and gas pedal.
    Senior Member jrcuz's Avatar
    Stafford Virginia
    I have the Wilwood pedals and used a cut off wheel to cut them vertically between the larger holes narrowing them by 1/3 of their width.
    JR
    I do have the Wilwood pedal kit. Thanks for the advise, but I do not have the pedals mounted on the brake and clutch arms. With just the brake arm, pressing it, my foot too easily over rides the gas pedal. I will see if I can get a picture today. Thanks again.
    X2 on the comments to move the Wilwood pedals over by using the different set of holes. It can help. I've also seen guys just cut them narrower as mentioned. Also I've see some cut the bottom corner of the brake pedal at an angle. That's often where your foot catches. Two other suggestions: The AC pedals that Mike Forte sells aren't too much narrower through the center. But do taper at the top and bottom and I've found they provide a little more room. Plus look pretty cool and bolt right onto the Wilwood pedal arms. Picture below.
    Also you'll probably find that shoes make a big difference. Like many, I've specifically sought out shoes that were as narrow as possible as still were comfortable for my size 11 wide feet. I have a couple pairs of shoes that I drive with and are fine. The rest get left in the closet.
    Santa Clarita, CA.
    Just throwing this out there.
    Shoe selection is also key. Does not matter what you do with the pedals if you are driving with big wide running shoes.
    Find a good narrow driving shoe or narrow soled sneaker. I drive in a pair of Vans.
    https://www.google.com/amp/s/heavy.c...ing-shoes/amp/
    Definitely something to consider. Thanks for the link. Maybe I can find a color to match the car, when I decide on the color.
    Jax Beach, FL
    I have big feet. I have to wear driving shoes. Puma makes "casual" driving shoes, which means without nomex. They really help.
    If you are into performance driving, don't forget about setting up for heel-toe shifting.
    Kirkland, WA
    That's next-level, right there. I never considered color matching my clothes!
    How about this, blue Shelby shirt, blue and white stripes on the car and blue suede shoes.
    I did a quick look at Van's. Everything is in medium width. Probably have to EEE my search.
    Almost forgot, blue and white striped overalls.
    Since I have size 13s I went with the all of the above method. I shortened the FFR pedal and modified the attachment to the Coyote lever arm. The brake and clutch pedals are trimmed and shifted left. Each modifications gains a fraction of an inch but they add up and make a huge difference. The driving shoes also make a big difference.
    That would make a difference for me. My drive by wire pedal has a plastic arm, so I have to do the work on the bolt FF arm and pedal. Your accel pedal looks to be close to the box wall, like I need. Tell me about the wear/heat plate you have on the box wall.
    That would make a difference for me. My drive by wire pedal has a plastic arm, so I have to do the work on the bolt FF arm and pedal. Your accel pedal looks to be close to the box wall, like need. Tell me about the wear/heat plate you have on the box wall.
    We have the same drive by wire pedal. I cut the plastic arm so it was just long enough to get two bolts into it and then made my own arm to locate the pedal where I wanted it. My goal was to move it back for more leg room since I moved my brake and clutch pedals back 2". In the process I moved it to the right a fraction. The stainless panel on the foot box wall is just a wear pad. I used lizard skin for heat and sound. I shaved the carpet a bit and was going to stitch and glue a rubber wear pad in place but I thought my shoe might drag on the rubber. I rolled the edges on the stainless and used countersunk bolts with nutserts in the foot box wall. I'm 6'6" and have a lot of leg and foot stuffed in that area so I had to spend a little more time modifying everything I could in the drivers footbox. Not necessary for everyone but it all worked for me.
    Thanks for the info on the side plate. Here are some shots of where I am now. 20190220_101742_resized.jpg20190220_101657_resized.jpg20190220_101742_resized.jpg
    The SS pad looks great and is a nice solution. I've purchased from these guys a couple times. http://www.heelpadwarehouse.com/heel-pads/. It's some type of hard plastic or vinyl. Similar to what's commonly installed in DD's. Shoes don't drag. If you want to go that way. This is from my currently underway Coupe build with one of the pads glued and stitched to the side wall carpet. Back on topic, the modified Coyote accelerator pedal is done using the cut off piece from the stock pedal, similar to what Factory Five now describes in their instructions. Works well. I moved the brake pedal to the left using the available holes since this picture was taken. Fits me well.
    Thanks for the option, edwardb. Neat job, as always, from you.
