Results 1 to 16 of 16
Thread: Front turn signal mount
    Janesville, WI
    The turn signal light housing touches in the middle before the rubber gasket can touch the body.
    Should I clearance the center hole in the body so the gasket acts like a gasket end touches the body and the housing.
    Second,I saw a picture in the directions that looked like the bracket that came attached to one screw at the front turn signal position and the other end was on the bumper bolts wasn’t installed. I am assuming that it must be installed. Also the holes that were factory drilled for the front turn signal light housing are about 1/16 inch to close together. I just elongated the bottom hole.
    Member JETAV8R's Avatar
    Apr 2018
    Wilson, NC
    I enlarged the center hole so the housing would sit flush.
    MKIV Roadster #9414, Complete Kit Delivered 9/8/2018, First Start 11/9/2018, First Go Cart 11/10/2018, Ford 306 Hand Built, E303 Cam, Blueprint Engine Heads, Edelbrock Performer Manifold, Edelbrock AVS2 Carb, Roller Rockers, Tremec T5, 3.55 Moser 3 Link, 17" Halibrand Replicas, Nitto 555 G2's, Power Steering, Power Brakes, Heated Seats, Russ Thompson Turn Signal
    Wait a little bit until Capt. O-Ring replies. He has a great solution but I don't know the specifics size.
    Janesville, WI
    Ok ��
    Santa Clarita, CA.
    Fairfax Station VA
    Like you, I had to oval the holes for the mounting screws, and like JETAV8R I enlarged the center hole so that the housing would sit flush. I also ditched the steel bracket that goes from the quick jack bolts to the turn signal pad; it interfered with my fresh air intake. I read in a Jeff Miller thread long ago that those brackets often have to be massaged so that the plane of the turn signal end lines up with the plane of the body in its final position; he just ditches them. Based on Jeff's information and the fact that loads of cars don't have those brackets, I felt comfortable getting rid of them.
    IMG_4688 by jhsitton, on Flickr
    MK IV Roadster #8631
    slpro1207's Avatar
    Moorpark, CA
    It’s the little things that make a difference. Looks like I’m making a trip to True Value. Thanks for reposting Capt. O’Rings (Jeff K.) idea.
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    The infamous Captain "O" Ring mod won't do anything to help the lamp sit flush to the body, it just hides the gap between the bezel & body (not to mention chapping Miller's a$$ but that's a different story ). The holes are generally all undersized so just open up the center as well as the ones for the mounting studs---you'll probably find that the rear is much the same. RE: the "horseshoe" brackets for the front corners...the intent is to stabilize the front but in my opinion they are only minimally effective since they mount to the little #10 studs that are just swedged into the marker light bases. Can't hurt, and I use them when I can (they won't fit around the ABS brake duct boots like the ones shown in John's photo without a lot of cutting/massaging/butchering) but I don't feel that they are crucial. With the fill length quick jack tubes and body grommets that have been standard for the past few years the front is quite secure without them...much more so than the old split tubes that sandwiched the body on earlier Mk4s.
    O'Fallon, MO
    I thought Miller likes chapped a$$. OH damn that was one of the things we don't talk about.
    Janesville, WI
    I just ordered some Orings. I had a tough time finding them locally.
    Thanks guys.
    Senior Member lewma's Avatar
    Jan 2018
    San Marcos, CA
    Guys, I'm having roughly the same problem. Here's a side shot of the front turn signals
    I have enlarged the center hole but the chrome ring does not sit flush with the back of the light so it leaves a pretty big gap. I emailed FFR this morning but they've not replied yet.
    mark
    Build 1: Mk4 Complete Kit #9312 Ordered 1/27/18, Delivered 3/24/18, CA SB100 Registered 9/11/19 - Gen 2 Coyote TKO600, IRS, Power Steering, Wilwood Brakes, 17" Halibrand.
    Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
    O'Fallon, MO
    Yep, thats the way they are made. Been like that for ever, you don't really want the metal ring setting against the paint. If it was, you couldn't remove the lens without scratching the paint.
    Quote Originally Posted by lewma View Post
    mark
    See post #5
    Jan 2018
    San Marcos, CA
    Dan from FFR replied and said that the lenses could be pushed out and reseated. Saw your reply Jeff, thanks. I'm going to see if I can push out and reseat the lense somehow. Overall a little disappointed with these lights.
    Jan 2018
    San Marcos, CA
    Good point rich. We do need little gap there so the lense can be removed. Didn't think of that!
    So. Bay (So. Calif.)
    Some others that seem to fit better. I used # RM00770, still has a bit of a gap, but better.
    https://jollyrogersmotors.com/store/c/172-MGA.html?pi=5
    Also, with a little trimming and messaging, the horseshoes will fit over the intake ducts.
