Thread: Return or Returnless 818R?????
    Jan 2019
    Which direction opinions with explanation wanted?
    Syracuse, NY
    That depends. If you are going to stay with the OEM computer you should stick with the returnless setup so the ECU does not throw fits. If you are using an aftermarket ECU you can do either, but I would recommend a return type system. With a return type system you have better fuel pressure regulation (assuming you are using a quality fuel pressure regulator).
    You can see some information in my build thread about it.
    Return type system diagam
    If you go with a return type system you can easily modify the factory fuel rails to work well.
    Fuel Rail Modifications
    MK3.1 Roadster completed 2011
    Jan 2019
    Ok, went return with a surge tank.
    Doesn't the wrx set up have a return line back to the tank after the regulator?
    USA
    Every WRX or STI that I've owned has been return style.
    Jan 2019
    Quote Originally Posted by Aero STI View Post
    yeah all 5 of mine had return style too....
    My NA impreza's have non-return. On big disadvantage of the non-return type is when you shut of the car you heat soak all the fuel lines on the engine. Then when you restart the is a chance of vapor lock.
    The return type constantly circulates fuel to the engine which help to keeps the fuel system cool.
