Results 1 to 8 of 8
Thread: Solution to high G oil loss
    Jan 2019
    I was thinking if you could close the valve cover breather hole on the high G side it would keep the oil in the engine. What about mounting and adjusting 2 tilt switches so they close at .8 g each direction they activate the electric valves mounted near the valve cover on the side that has the tilt switch tripped. Crazy? Too complicated?
    Syracuse, NY
    Why not just buy the Killer Bee Oil Control Valve if you want to close off the high G side. It appears to be completely mechanical and dead simple to install. No chance of electrical issues / gremlins.
    MK3.1 Roadster completed 2011
    Bowling Green, KY
    I am using the KB OCV works great with the KB pan/pickup and Arctangint oil control plate.
    Jan 2019
    Exactly the pieces I have ordered, the last piece I need to order is the KB OCV. Probably what made me think of this.
    But if it was connected to the vehicle roll/pitch/Yaw sensor it could be even more effective than KB design. I do come from German cars so complex is in my nature!
    Bowling Green, KY
    The valve is very simple that is the beauty of it, a couple of ball bearings open and close as the car is loaded right to left. I have a ton of track miles on my car without issues. My build philosophy from the start was to keep it simple and easy to work on.
    Senior Member Rob T's Avatar
    Woodruff, SC
    I have to echo what Mitch says, not just for oil. I have had a number of track days cut short because something wasn't doing what it was supposed to (clunking CV, erratic temp sender). I always took the safe route and went home. Never really got my entrance fee on those days. I'm an engineer who runs a factory. The temptation for cool solutions is large and they can work. I now aim for robustness....maybe not as sexy, but works day in and day out.
    Jan 2019
    You guys are right of course, KISS always applies. I was just dreaming up a solution probably more for factory cars that is built from dependable parts after millions or test miles. Now a days the sensor and solenoid and actual moving part are capable of reporting if they dont work so factory solutions at least are less error prone.
    Woodruff, SC
    I am happy we are going to have another car on the track. We all keep learning and benefit from each other's experiences (good and bad....). I forgot to mention one other "short day" when I lost my brakes. Some combination of a really short, twisty track and not changing the fluid often enough. Mostly operator error on the fluid.....
