5
Ducky2009
I added a 2 1/4" push-out on the heater to allow more room for a deeper glove box. See pic. I made the glove box via welding aluminum. You could accomplish the same riveting it together. I also made a competition dash and new firewall from 3/32" thick aluminum, so it would be stiffer them the FFR dash. I made a tool to form a countersink shape, not countersunk with a cutting tool. See pics in my library.
https://thefactoryfiveforum.com/album.php?albumid=1073
As Paul said, every imperfection (high or low fastener) will show. You also might consider using an 1/8" padding. Check out "Closed Cell 2A Volara Foam Landau Padding", 1/8" thick", from Headliner Magic,
http://www.headlinermagic.com and leather for a dash cover. Got my leather from Tandy Leather for about $100. Much nicer look. Just a suggestion.
NOTE: I have extra 1/8" padding if you want some. Just pad for shipping. Shouldn't cost much.
Thanks Ducky, I may take you up on the padding offer. I'm not 100% sure which way I'll go yet on the dash padding, but I could always pass it onto someone else if I don't use it.
Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
Serial #9158
