Thread: Wanted -- drivers side door latch assembly
    Feb 2018
    Hi All,
    I bought a Mark I about a year ago and today my drivers side door latch assembly bit the dust. No amount of fiddling with it helped.
    I went to Factory Five to buy a new one and the web-site says they're out of stock. I'll give a call tomorrow, but I'm not too optimistic.
    Does anyone have a drivers side latch assembly they would like to sell.
    Contact me at [email protected].
    Tom
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    I'm sure I have anough parts here for a driver side latch assembly if you don't need the chrome cover.
    If FFR doesn't have one send me a message!
    You are aware about a repair to the latch? Using a carriage bolt?
    http://www.linger.com/cobra/DoorLatchRepair.htm
    Ralph Button
    FFR 1436 (PROUD Owner of an Original Mark I)
    400,013 miles as of 11/1/2009
    417,840 miles as of 8/12/2010
    435,021 miles as of 12/19/2011
    Now a well broken in 347 engine
    523,145 miles as of 7/29/2014
    601,165 miles as of 6/1/2018
    615,215 miles as of 4/23/2022
    "It's not about the destination, it's the about the journey. And where is your journey taking you?"
    "... Not all who wander are lost!... --J.R.R. Tolkien
    Mar 2013
    Fort Collins, Colorado
    Does your latch have the carriage bolt instead of the original pivot shaft ??
    Back in the days of the mk1's and 2's, the latch was greatly improved by switching out the shaft with a carriage bolt and some washers. The thread for that mod is probably lost in the archives, but maybe someone knows where to retrieve it.
    Many latches were saved from the trash.
    Fairfax Station VA
    Door latch fix thread: http://www.linger.com/cobra/DoorLatchRepair.htm and a thread with some amplifying information: https://thefactoryfiveforum.com/show...8-Door-Latches
    Thanks Wade!
    MK IV Roadster #8631
  5. Thanks Derald Rice thanked for this post
    Senior Member weendoggy's Avatar
    Aptos, CA
    That latch mod works "only" if you use spacers behind the mounting plate, OR, if you recess the door area itself. It won't work having any of the carriage bolt head protruding past the base and sitting flush on the door.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
